First post, by raerek
I am quite on the beginner side of MIDI and MIDI emulation. Please help me clarify:
From what I understand FluidSynth (or Timidity++) can be and is used to emulate eg. SC-55.
One can get MT-32 sounfont(s).
Munt emulates only MT-32.
What is the purpose using both FluidSynth and Munt?
Thank you for your answer.
Reply 1 of 5, by Kaminari
Munt emulates a real MT-32.
A soundfont is an approximation -- and can't reproduce an MT-32 anyway, since the MT-32 instruments are programmable.
Ryzen 5600X 4.6 GHz | Radeon RX 6650 XT 8 GB | DDR4 32 GB | Win10-64 Pro
Reply 2 of 5, by raerek
Thanks for the answer:)
This part I understand: "A soundfont is an approximation"
This one not really: " -- and can't reproduce an MT-32 anyway, since the MT-32 instruments are programmable." - AFAIK folks do use FluidSynth in DOSBox (ECE, maybe) to emulate SC-55 or later models. Am I wrong?
Reply 3 of 5, by Dominus
Rank DOSBox Moderator
DOSBox Moderator
They use Fluidsynth as a General Midi device.
But some Dosbox builds (I think ECE for example) use a built in Munt to emulate a Roland MT32 device
Windows 3.1x guide for DOSBox
60 seconds guide to DOSBox
Reply 4 of 5, by Shreddoc
SC-55 (and many other General MIDI devices of the era) generates it's basic sound palette by accessing a bank of preset sounds, similar to how Soundfonts function. That is why Soundfont-based systems can be used for emulation.
MT-32 (which is not a General MIDI device) generates it's sound palette PARTLY by the above method, but ALSO by certain unique methods involving custom sounds and real-time calculations. Therefore, soundfonts cannot by themselves suffice to emulate an MT-32. The application "Munt" was written specifically to fill that MT-32 niche, with the necessary real-time capabilities in addition to the stored bank sounds.
Supporter of PicoGUS, PicoMEM, mt32-pi, WavetablePi, Throttle Blaster, Voltage Blaster, GBS-Control, GP2040-CE, RetroNAS.
Reply 5 of 5, by raerek
Now it is clear.
Thank you.
