First post, by auron
those aren't the easiest to capture on screenshots, but to clarify the point, a few shots from the opening of opposing force (same thing happens in vanilla), of some fairly light cases:
The attachment of1a10001.png is no longer available
The attachment of0a00000.png is no longer available
The attachment of0a00001.png is no longer available
The attachment of1a10000.png is no longer available
the shots are from a voodoo5 in d3d, latest stock 98se drivers, but this occurs on a wide variety of video hardware (3dfx v3/v5, nvidia, kyro) in both d3d and ogl, only the software renderer seems to improve things at all. i only have the blue "generation" box as the earliest versions to test, but it's the same between those versions and the last patch.
it's hard to find any info on this but i seemed to remember that running -32bpp would fix this due to presumably improved z-buffer precision but that is not the case, some console commands i tried didn't help either. there's z-fighting issues on decals that are fixable by playing with gl_polyoffset of course but that doesn't affect it otherwise. i did watch a bit of voodoo2 footage where i had trouble spotting these issues though and cannot seem to remember them at all from the steam version...
Reply 1 of 4, by OpenRift
Sorry to necropost, but I've had similar issues on my Voodoo 3 2000, have you found any solutions for this in the past decade?
Reply 2 of 4, by swaaye
I used to force 32-bit Z buffer on the G400 to fix flickering decals in some games. Not all cards support a 32-bit Z. I still see problems like this in modern games.
I'm not sure the cause of the seams between textures/polys. Undoubtedly this could be caused by the game's renderer. This is something that will vary between cards as well. Riva 128 had seams everywhere for example, some kind of pipeline precision issue no doubt as that chip had lots of compromises for speed.
Reply 3 of 4, by leileilol
looks more a gl_keeptjunctions issue
long live PCem
Reply 4 of 4, by OpenRift
leileilol wrote on 2026-01-04, 06:01:
I thought so too, I've tried that and it doesn't seem to make a difference at all, even after setting it in the autoexec.cfg. I don't know if being on a Voodoo 3 has anything to do with it.
