First post, by BEEN_Nath_58
I have the game Test Drive Off Road 2 which doesn't use Glide, the one that used software rendered 3d graphics. The problem is it only runs at 13fps. I put DDrawCompat and dgVoodoo over it but the result is same. Is the game supposed to run this way?
Is this resembling something to Quake's 3d software rendering on cpu?
Reply 1 of 1, by Macron
Just tested "Test Drive Off Road 2" with dgVoodoo glide emulation and got the same 13 fps!
