First post, by Takedasun
Video card Nvidia Riva 128.
How do I turn off vertical synchronization (vsync) in Direct3D games?
Reply 3 of 7, by Takedasun
Riva Tuner not support.
PowerStrip
8.49 KiB
12.59 KiB
210.86 KiB
258.97 KiB
Frequency limited to 60 fps
Reply 4 of 7, by The Serpent Rider
Probably can be disabled directly via registry tweaking.
disabling vsync on riva 128 or TNT is not allowed
OpenGL already has Vsync disabled.
Reply 6 of 7, by Takedasun
The Serpent Rider wrote on 2021-01-04, 05:29:
[HKEY_LOCAL_MACHINE\Software\NVIDIA Corporation\RIVA 128\Direct3D]
"NOVSYNC"=dword:00000001
is not working
Reply 7 of 7, by The Serpent Rider
Looks like you'll have to switch between drivers. Some should work.
