First post, by freenit
								freenit
								Offline
			Hi, this game only works with directory mounted as a.
I want to make it portable running in any computer and in any path.
Making a bat file and dragging it on dosbox icon.
when i type:
mount a "c:\pc\Bumpy" -t floppy
bumpy.exe
game is running ok.
but...
when i type:
mount a . -t floppy
dosbox mounts as drive a the dosbox local directory, not the game directory, that's the problem...
any help ?
thanks.
edit: found a solution, is to put dosbox in the same game directory.
