First post, by carlostex
Hi there,
i wrote a program to change the General MIDI port on the Miles drivers which are packed. The driver port is always 330h, and if you have different General Midi daughterboards on other ports then this program is for you.
A few things to keep in mind:
- This is for the CD version only; (who wants to play the floppy version when you can have Patrick Stewart?)
- This assumes you copied your CD contents into the harddrive, to a \CD subdirectory inside your main game folder; (files in CD's can't be written)
- After you use the program then you can use FakeCD to mount the files into a D: drive and play;
- Remember if you want to play on a MT-32, you might want to repatch for port 330h;
Enjoy, and let me know if it worked for you.
LOLPORT.exe
2.05 KiB
76 downloads
EDIT: Here's an updated version of this tool. In similar fashion to what i did for Lost Vikings, this version allows a specific user input defined port.
lolmpu.exe
2.06 KiB
76 downloads
Reply 3 of 7, by carlostex
A lot of refinements made, probably last version of the tool. It is now (hopefully) completely dummy proof. Invalid characters will be denied, and only 3 actual characters are possible to input.
Some code optimization made too, with much better multiplication. Not that a simple tool needed it, but i'm OCD.
Reply 4 of 7, by Peter.Mengel
carlostex wrote on 2021-01-25, 15:46:
Hi there, […]
Hi there,
LOLPORT.exe
lolmpu.exe
Hi any tip about FakeCD? Ive found FakeCD 99 but nowwhere to download. I own a CD of the game but i cant modify it. Thanks for the Tool.
Reply 5 of 7, by Pierre32
Peter.Mengel wrote on 2022-07-31, 03:16:
This is what you're after: http://www.math.uni-rostock.de/~nfa506/fakecddr.html
Reply 6 of 7, by Peter.Mengel
Pierre32 wrote on 2022-07-31, 03:37:
Ive found my Virtual CD6 CD today its working like a charm, Copy files to HDD...edit them. And then bound them back as a virtual Drive. But i wish i could get my hands onto FakeCD99
it had a Gui back then if iam not wrong.
Reply 7 of 7, by Peter.Mengel
Peter.Mengel wrote on 2022-08-02, 14:26:
Ok to anyone who founds this...i remembered why i dumped the CD back then as trash in the basement for forever...Virtua CD6 did work shit!....It always unmounted the images and caused plenty of Problems...so back to the trash with it....
