First post, by avxstudios
Hey all,
I've got an Aiwa PC-MT601 (Win95 based All in one) which has a CS4232 on the motherboard along with an OPL3, I've tried a bunch of drivers but getting mixed results, the only ones that seem to work at the ones in the ORCHID3D folder on the Win95 disk.
Sound seems to work fine in Quake, and in Heretic, but for games like Doom and Duke3d, even when selecting the same sound setup as I did in Heretic, there is both no music and no SFX.
The other issue is the card shows up as 4 devices,
Orchid NuSound PnP 32
NuSound PnP 32 Audio
NuSound PnP 32 Gameport
NuSound PnP 32 MPU-401
The latter three install fine, but the Orchid NuSound PnP 32 gives a yellow exclamation stating Code 28 drivers not installed correctly, but when I point it to the same Orchid3D folder as the other drivers installed fine from, it doesn't seem to find anything, and weirdly if i run the setup program in the orchid3d folder, it gets so far then asks for disk 2.
If i try other drivers I get varying degrees of the same, issue with other CS4232 drivers only installing on 2 of the 4, or none at all.
Any ideas on the best approach with this?
Here's the motherboard :
Also if anyone can ID this card, I'd be appreciative / impressed.
