First post, by Digidreamer
Hi,
Can I pick some brains, I've acquired a unused Wyse V10l with dual monitor out put, can't find any spec for the secondary video card, don't think it's the same as the on board video, connects as a daughter board over the main board, has a heat sink over it so can't see the chip. Win98 didn't pick up the driver installed for the onboard.
Any one out the know about the vx0 Variants?
Thanks in advance
I Like Charity Shops, they're like steam and GOG but cheaper.
Windows 98se - Wyse V10LE 1.2Ghz, 1 Gb, 16Gb SSD
Windows 98se - Compaq Evo 550d SSF, P4 2Ghz, 1Gb, 60Gb(Partitioned)
Dos 6.2 - HP7510 512Mb, 4Gb
Reply 1 of 3, by darry
PCILIST should help you ID the other VGA controller in the machine, if there is one and if is PCI based. https://www.majorgeeks.com/files/details/pci_list.htm
What is the primary VGA controller? Are you sure it does not simply have 2 outputs ? EDIT: I mean two DVI outputs handled by the primary VGA controller .
Reply 2 of 3, by Digidreamer
it has a separate card for the second (primary) output, on board becomes secondary, (not supported by win98, memory issue)
my other one only has one out put that splits by the cable.
data for the card is pretty much no existent
i'll give pclist a try over the weekend,
if it's better than the onboard it can stay, if not, it go s, got a pcmcia slot to fit.
Reply 3 of 3, by Digidreamer
Didn't understand a lot of the details, but saw ATI mentioned,
Had some catalyst drivers for my t5710, installs as Radeon 7000 series,
for anyone who follows
Radeon 7000 Series 16Mb PCI
win98 SE,
Catalyst 6.2
Thanks
