First post, by mt777
Fresh OS, creative drivers installed, no conflicts in device manager . Diagnose didn't ask about testing onboard dram and finally AWE Synthesized music option is missing. About 1/10 reboots - diagnose will ask about testing dram and then AWE testing option is appearing.
PNP OS installed - disabled in bios.
I checked also with other Gold cards which tested earlier in another board.
Checked also without installing Creative drivers (only native drivers from 98). Empty Autoexec, the same issues.
Reply 1 of 2, by darry
mt777 wrote on 2021-02-04, 00:56:
Fresh OS, creative drivers installed, no conflicts in device manager . Diagnose didn't ask about testing onboard dram and finall […]
Is your ISA bus running faster than 8MHz or so ?
Reply 2 of 2, by Joseph_Joestar
If you are installing DOS drivers under Win9x, you need to use a special process:
https://www.youtube.com/watch?v=ZiSM5pUGab4
Try that method if you haven't already and see if diagnose.exe behaves the same. If it still fails, it could be a hardware issue.
