First post, by red_avatar
- Oldbie
Like the title says, I'm a bit stumped.
My on-board chip is a Cirrus Logic one (GD5428) that has a mere 512kb of memory, not enough to run Windows 3.1 in 65k colours which is what I'd like (not for gaming, it's for using an old handscanner I bought).
So I bought a slightly older Cirrus Logic card - the CL-GD5422 - with 1MB of memory. I've tested it in my Pentium 75 before and it works fine but it was too slow compared to the on-board chip (which was a 32bit bus PCI graphics "card") but when I plug it in the IBM (Valuepoint 425SX), it clearly detects it since the BIOS now shows it as the active card and on start up, I see the data in the top left ... but I get a black screen. If I connect it to the old on-board VGA port, I get an image. This is very weird - and clearly the card does not output to the old VGA port either (would that even be possible?) since I still cannot use 65k in Windows (the drivers for the GD5428 and GD5422 seem to be compatible so they work on both).
I know the card is going to be slow but that's not the point of using it - I just want Windows 3.1 to run in true colour mode.
Does anyone have any idea why this would be?
Retro game fanatic.
IBM PS1 386SX25 - 4MB
IBM Aptiva 486SX33 - 8MB - 2GB CF - SB16
IBM PC350 P233MMX - 64MB - 32GB SSD - AWE64 - Voodoo2
PIII600 - 320MB - 480GB SSD - SB Live! - GF4 Ti 4200
i5-2500k - 3GB - SB Audigy 2 - HD 4870
