First post, by FeedingDragon
- Oldbie
Cannot get it to even start now. Though I don't remember if I had it running before, or not, in DOSBox.
The setup program on the disk doesn't work... I seem to recall it didn't work back when either. There's not room on the disk, and the backup batch never worked either. That being said, I got around it by just running cygnus.com to start up. Though I distinctly remember having to turn off turbo to play the game. However, in DOSBox (and I've tried may settings,) as soon as I answer the first question (large or small version,) it just stops (never starting the game.) I've tried with SVN & 0.74. I've tried normal, simple, & dynamic core. I've tried with cycles from 250 to 1000. I've tried CGA, EGA, & VGA graphics.
Anyone know what else to try? Or better yet, what actually works 😀
Thank you.
Feeding Dragon
