First post, by Bumrusher89
Hello.
I am questioning the localtsrs line on the Non Windows app section on the Windows 3.1 system.ini file. I was wondering if you can enter in other tsr programs like mo'slo on the localtsrs line. And how do you list them on the localtsr line? I just need help on using the localtsrs line on [Non Windows app] on the Windows 3.1 system.ini file.
Also according to the manual that many tsrs wil not run properly if they are added to the list. It also says you need to make sure if it's compatible with windows and can be copied to a virtual machine before adding it to the list.
