First post, by colt
Mounted the dir where gp2 folder is located. I then move to there and execute gp2.exe.
The result is:
DOSBox switched to max cycles, because of the setting: cycles=auto. If the game runs too fast try a fixed cycles amount in DOSBox's options.
and a black window where I can read
Cpu speed: max 100% cycles
Running dosbox 0.74.2 compiled from the source.
