First post, by johnyept
I'm trying to install Windows 98 SE on a ECS K7S5A motherboard, Athlon XP 2400+, 512MB DDR and 120GB IDE HDD, but I keep getting the "Windows Protection Error" after the installation is finished. I also tested with 256MB DDR and CPU running at 1800+ (FSB 100/100) but got the same result.
I usually use Hiren's Boot CD to create a single partition on both drives, format them with FAT32 (FAT32 Formatter) for Windows 98 SE and NTFS for Windows 2000, copy the installation files from a flash drive to the 1st HDD, then boot from DOS and start the installation. I use a MSBATCH.INF for an (almost) unattended install, so I can do this over and over again until I figure out what the heck is going on. The installation starts fine (config.exe /ie /is), copies the files, reboots, detects the hardware, reboots for the final time and... Windows Protection Error. I can run it in safe mode, but that's it. If I use Windows 98 SE fdisk, it creates a 48GB partition instead of 120GB, but the end result is the same.
Except for a 5.25" Floppy drive, I added every "odd" hardware I had lying around, could it be conflicting somehow? It shouldn't be a problem since no drivers have been installed yet...
- Motherboard: ECS K7S5A
- CPU: Athlon XP 2400+
- RAM: 256MB or 512MB DDR
- IDE1: HDD WD 120GB (FAT32 for Windows 98SE) + HDD WD 320GB (NTFS for Windows 2000)
- IDE2: IOMEGA 100 ZIP drive + HP CD-Writer
- Floppy 3.5" 1.44MB drive + HP Colorado T1000 (connects to Floppy cable)
- PCI SCSI card + SCSI HP CD-Writer
- PCI SBLive
- PCI TV Card
- AGP Geforce 4 MX 440 128MB
I doubt it's the BIOS limitation causing havoc with the HDD size, so I'll try with a smaller 40GB or 20GB tomorrow just to be sure that's not it. I had a better/newer motherboard for the Athlon XP, but it stopped working all of a sudden, probably due to bad capacitors or bad power supply. The older the hardware, the trickier it is to handle...
RETRO-W98/2K: MSI MS-6309 v1.0, P3 1Ghz, 3x256MB, GF5600 128MB AGP, VD2 PCI, RTL8139D PCI, TB400-2541 PCI, ESS1868F ISA, 160GB IDE
RETRO-WXP/7: ASUS P5KPL-AM EPU, XEON E5450 3Ghz, 2x2GB, GTS 450 1GB PCI-E, 120GB SSD, 1TB sATA
