First post, by mothergoose729
Does anybody know of a decent launcher/frontend for older versions of windows? It would be really nice to have a full screen menu where I can see (ideally) a description and some box art from which I can launch my games . I don't need it to do much more than run batch scripts.
I use launchbox for my modern windows machines but it requires later versions of .net, not to mention it is way too heavy for my slot 1 machine. So it needs to be light weight and performant in addition to compatible with older versions of windows.
Reply 1 of 14, by cyclone3d
You should be able to make one yourself pretty quickly with an older version of AutoIT Script.
https://www.autoitscript.com/forum/topic/1086 … -on-windows-98/
To add games or other programs, you could set it up to read from a configuration file.
Each program would have a line for what to run and what image to display.
Yamaha XG repository
YMF7x4 Guide
Aopen AW744L II SB-LINK
Reply 2 of 14, by xcomcmdr
DOSBox games or all kind of games ?
Reply 3 of 14, by mothergoose729
xcomcmdr wrote on 2021-03-30, 07:48:
All kinds of games. No emulation but I might add that in later.
cyclone3d wrote on 2021-03-30, 06:03:
You should be able to make one yourself pretty quickly with an older version of AutoIT Script. https://www.autoitscript.com/foru […]
I was hoping for something turn key but I can take a look. The release notes indicate it stopped supporting 98 in 2015 though.
Reply 4 of 14, by bofh.fromhell
You could do it in HTML.
I think earlier IE versions have no problems running things locally.
Cant remember if they support kiosk mode tho for real fullscreen.
And hey, maybe a use for active desktop 🤣 =)
Reply 5 of 14, by xcomcmdr
I might have a solution soon.
Is .NET 2.0 acceptable ?
Reply 6 of 14, by mothergoose729
bofh.fromhell wrote on 2021-03-31, 12:29:
You could do it in HTML. I think earlier IE versions have no problems running things locally. Cant remember if they support kios […]
You know that isn't a bad idea! Once I get a good template I can just copy and paste. Plus I am a web developer by trade so it would take me less work than learning another scripting language.
xcomcmdr wrote on 2021-03-31, 12:32:
Interesting! Yes of course! Are you already working on something?
Reply 7 of 14, by xcomcmdr
I have a front-end that works with DOSBox, 98, XP, and beyond.
Only a little tweaking would be required in order to tell it to launch the EXE/BAT/Whatever directly instead of using DOSBox.
Reply 8 of 14, by xcomcmdr
Here it is :
https://github.com/maximilien-noal/AmpShell/r … ases/tag/v1.3.4
(just download AmpShell.zip and open the 'For Windows 98 users' folder for the .NET 2.0 version).
The regular version uses .NET 4.0 and works with XP or later.
If you don't have .NET 2.0 Framework for Windows 98, it's on OldApps.com (I don't know if it's allowed to link to it on VOGONS, probably not ?)
Keep in mind that .NET 2.0 needs Internet Explorer 5 (edit: or later) and Windows Installer 2.0.
(I have those too if you need them)
On first start up it will search for DOSBox, and upon not finding it, ask for it. Just say 'no' and it should run anyway.
Once the front-end is launched, you can go to Options -> Preferences -> Behavior and uncheck 'Use DOSBox to launch games'.
It should then A) Not use DOSBox to launch games and B) Not bug you about not finding DOSBox the next time you run it.
BTW, in the same Preferences window there is a tab where you can set a bigger size for the icons. Up to 256x256. Might be preferable for box art.
Reply 9 of 14, by RandomStranger
I don't know about 98, but I use Metropolis Launcher for XP. It's looks a little archaic and I found it to be slow (most likely slow database access, because it equally slow on a P4 and a Core2 Quad), but that's the only one I know that has all the features I need for XP.
Reply 10 of 14, by mothergoose729
xcomcmdr wrote on 2021-03-31, 21:59:
Here it is : https://github.com/maximilien-noal/AmpShell/r … ases/tag/v1.3.2 […]
Here it is :
Or first start up it will search for DOSBox, and upon not finding it, ask for it. Just say 'no' and it should run anyway.
Looks awesome! I'll give it a shot this weekend.
RandomStranger wrote on 2021-04-01, 12:40:
That frontend looks very nice. It looks like it requires .net 4.0 but maybe that is a "soft" requirement and it will work under .net 2.0.
Reply 11 of 14, by RandomStranger
mothergoose729 wrote on 2021-04-01, 13:38:
Nope. Once I forgot to install .net 4.0 before starting the Launcher. It's definitely a "hard" requirement.
Reply 12 of 14, by xcomcmdr
I uploaded a release where the feature of "not using DOSBox globally or for a particular game" works even if no DOSBox.exe exists (oops!). I'm using it on a real Windows 98 machine. 😀
Reply 13 of 14, by RandomStranger
It's been a while, but today I've decided to check out some launchers since I've started to grow dissatisfied with Metropolis Launcher and thought, I just give an opinion on them, so...
Metropolis Launcher
Comes with a huge built-in database you can edit. Problem is, it's very slow, and don't really know what. For a time I thought it wastes a lot of time trying to access online databases to update its own, but even if I disable the function, it takes 20-25 minutes to open my game library.
It records a lot of statistics, which I like, but the games have to be launched from Metropolis Launcher for that to work.
Requires at least Windows XP SP3 and .NET Framework 4.0
LaunchBox (3.2)
The current dosn't work on XP, this old one however does. Probably the most well-known of the bunch. The games has to be added manually, and unless the PC has internet connection game data has to be added manually. I like the game library a lot more, and it's a lot faster than Metropolis, however the only stats it logs is the date and time for the last launch of the game, but it only works if you launch the game through LaunchBox. The game library has several filtering and arrangement options.
Gameplay Time Tracker
Game-Hub-Game-Time-Tracker-2.png Game-Hub-Game-Time-Tracker-3.png Game-Hub-Game-Time-Tracker-4.png Game-Hub-Game-Time-Tracker-5.png
This is also a fast one, maybe even works as far back as Windows 2000, maybe I'll check some time later. This one supposed to recognize games based on hardware utilization, but you can add executables to a a list to (or not to) recognize certain applications as games. It draws charts, logs game stats, runs in the background and you don't have to launch the game through the app for it to work. You should be able to add games to the game library by hand, but for me the menu was inactive, however games automatically added once you launched them (it works with version 3.0, but that one has stability issues). Metadata is extracted from the executable and can be edited by hand.
I think it's best to be used in tandem with LaunchBox to combine their strengths.
Xfire
https://github.com/darcymiranda/PFire
Apparently servers for it can be emulated, though I think it needs at least Windows 7, the client itself should work maybe even on Windows 98. I only have vague memories of this one, I think it wasn't really designed to be used like this, but it was beloved in the noughties, so I included it.
Reply 14 of 14, by aazard
Necro..
Found 3, NOT including the AWESOME, AmpShell https://ampshell.tuxfamily.org/
Use AmpShell's Net Framework 2.0 version on Windows 98SE
QTbar 1.3 - old but good https://michael.team/qtbar/
Bar
Bar Open
Settings
DOWNLOAD: http://files.nozbe.com/qtbar/qtbar_1_3_en.exe (right click > "save as")
LaunchBox for MS-DOS Special Edition 2.0 - AWESOME! Technically DOS, needs NEC V20/V30 or 286+ (286 instructions used) https://forums.launchbox-app.com/files/file/9 … pecial-edition/
https://youtu.be/LulhGUaR2Yc
DOWNLOAD: https://forums.launchbox-app.com/files/file/9 … c12e79c1cfaf497
GameEx -works in 98SE with net framework 2.0 (tested GameEx 10.35 released Jan 4, 2010. Last using Visual Studio 2005 not Visual Studio 2008) https://forums.gameex.com/forums/topic/2331-g … ead-this-first/
https://www.gameex.com/vid1.mp4
DOWNLOAD v10.35: https://www.zophar.net/frontends/universal/gameex.html
Aazard -
Mono Planar Mortal & Unascended Master
Retro Enthusiast & L3 Trouble Shooter
.... Getting old
