First post, by CBM
hi
I have this ISA hardcard
and I found out that I need a driver in order to write to it, I can read from it without a driver
https://www.seagate.com/staticfiles/maxtor/en … ard_jumpers.pdf
atdosxl.sys
but I cant find it anywhere
according to the documentation:
"Must be installed in CONFIG.SYS as:
DEVICE=ATDOSXL.SYS"
Main PC SPECS:
CPU: AMD Ryzen 5 2600
GPU: Powercolor Red Devil Radeon RX 5700 XT
RAM: 8GB*4 Corsair Vengeance LPX DDR4 3200MHz
Motherboard: ASUS Prime B450M-A
PSU: Corsair RM850
Reply 1 of 12, by weedeewee
Normally you do not need any driver for that card.
Just set it to a free rom address & irq, and plug it into a pc without any harddrives.
This should make it show up as a drive in fdisk under dos.
edit: looking at the photo, your card is currently set for rom bios address CC00, IO 170, DS 1? and IRQ 11
edit2: DS is drive select set to second drive.
edit3: Just set it to the default settings, plug it into a harddriveless computer and if an OS is present on the disk, and the disk is still working the computer should boot from it. If not, you should be able to install an OS on it. No driver required for that.
Do not ask Why !
Reply 2 of 12, by darry
CBM wrote on 2021-04-04, 13:04:
hi […]
hi
atdosxl.sys
DEVICE=ATDOSXL.SYS"
Not sure if the driver is actually required for writing or if it is a different issue , but driver is here : http://ibm-pc.org/firmware/other/plus%20hardc … %20hardcard.htm
or attached here :
Hcard2XL.zip
343.62 KiB
27 downloads
Reply 3 of 12, by CBM
darry wrote on 2021-04-04, 14:08:
Not sure if the driver is actually required for writing or if it is a different issue , but driver is here : http://ibm-pc.org/f […]
hi […]
hi
atdosxl.sys
DEVICE=ATDOSXL.SYS"
or attached here :
Hcard2XL.zip
Thank you very much! PCRetroTech at youtube found the same link.. I think this is the one I need..
The manual states the driver is needed
Main PC SPECS:
PSU: Corsair RM850
Reply 4 of 12, by weedeewee
Speaking from personal experience with a 20MB hardcard. I have never used a driver. Didn't even know one existed.
Do not ask Why !
Reply 5 of 12, by CBM
weedeewee wrote on 2021-04-04, 16:49:
well I have never been able to write to the card only read
and after researching the 105 model, I discovered that when this card does not have the driver loaded it can only read from the disk but with the driver for dos it can read and write data according to its documentation
must test it though
Main PC SPECS:
PSU: Corsair RM850
Reply 6 of 12, by weedeewee
CBM wrote on 2021-04-04, 18:51:
well I have never been able to write to the card only read […]
must test it though
that just seems odd to me, and highly annoying. 😀
Hope it works with the driver ... Wonder how it will function in windows or linux
Windows will probably be able to fall back on the bios routines but linux doesn't have that luxury.
Do not ask Why !
Reply 7 of 12, by CBM
weedeewee wrote on 2021-04-04, 19:07:
that just seems odd to me, and highly annoying. :-) Hope it works with the driver ... Wonder how it will function in windows o […]
must test it though
well windows is supposed to be able to handle it without mystic drivers but the card does not like fast computers but perhaps it will work well in an early pentium system with windows 95
Main PC SPECS:
PSU: Corsair RM850
Reply 8 of 12, by darry
CBM wrote on 2021-04-05, 11:44:
must test it though
This in the linked pdf makes that an unlikelt scenario : "Due to a bus timing issue, the hardcards are unable to work in most Pentium and DX4 systems."
Though they will work under Windows 95, they do so in `DOS Compatibility mode'. No enhanced mode driver exists at
this time, and there are no plans to produce one."
Nonetheless, good luck.
Reply 9 of 12, by weedeewee
from the pdf you linked ...
Do not ask Why !
Reply 10 of 12, by CBM
yes
it would need to be a very odd system indeed if it could run win 95 and also use the hardcard
Main PC SPECS:
PSU: Corsair RM850
Reply 11 of 12, by emosun
i also have the hardcard 105 and have installed it into a windows 95 era packard bell , and yes you can read the drive and pull info off of it but you cant write to it. My goal however was to simply rescue the data from it before it possibly dies.
My hardcard 105 turned out to have a windows 3.1 installation on it.
