Bare 3Dfx Voodoo 2 board pictures
First post, by TelamonLivesOn
Hello all, I am currently looking for high-res pictures of bare 3dfx Voodoo 2 boards. Since I know that some Voodoo 2's are broken and are likely being harvested for parts for other cards, I was wondering if someone could send me bare board pictures. I need them for a project I am working on that will attempt to reverse-engineer the reference board design, and by extension the voodoo 2 chipset. Looking at populated board pictures is difficult when attempting to find hidden traces. Preferably, I want close-up pictures of both sides so that I can easily match holes going between each side. Thanks!
Oh, and the pictures don't have to be of any Voodoo 2 card in particular, they just need to be the reference design (not some weird Quantum3D boards).
Reply 1 of 29, by Warlord
I've never seen one alternately you could buy a broken voodoo 2 and use some hotair to remove all the components then you can check traces. Id think more info could be learned from that than looking at a picture assuming one exists in the quality you want.
Reply 2 of 29, by TelamonLivesOn
Warlord wrote on 2021-04-09, 18:33:
I found good-quality pictures of populated boards, but some of the traces go under the RAM, so I can't figure out where they actually go. Unfortunately, I do not have a voodoo 2, but I want to build one from components and a custom PCB, which requires me to reverse-engineer the chipset, as pinouts have not been released for it.
Edit: Not to mention that even a broken card would cost way too much in today's market ($150 for an average broken one).
Reply 3 of 29, by Warlord
you can buy working ones for 150 if I check sold listings people have bought working ones for around 100. I assume you could find a broken one for less than 50.
In all honesty to have PCBs made, get all the chips to go on one, you are looking at more than 150 dollars that way, but I could be wrong. Never the less good luck I'll be eyeing this thread.
Reply 4 of 29, by TelamonLivesOn
Warlord wrote on 2021-04-09, 18:57:
I'm not building just any voodoo 2 😉 It's going to be a custom one with a unique board design, but I first need to reverse-engineer the board. Now that I think of it, I can find a working board somewhere for less than $50 excluding shipping and tax.
Edit: I may have to sacrifice a possibly working one for research.
Reply 5 of 29, by TelamonLivesOn
At least the rest of the voodoo 2 docs were released, meaning that I don't have nearly as much work to do.
Reply 6 of 29, by cyclone3d
I need to go through my V2 boards. I know I have some non-working ones.
If there is one that I can't get working, I would gladly send it to you for the price of shipping.
Yamaha XG repository
YMF7x4 Guide
Aopen AW744L II SB-LINK
Reply 7 of 29, by TelamonLivesOn
cyclone3d wrote on 2021-04-09, 19:51:
Thank you very much for the offer 😀.
On another note, does anyone know any good pcb x-raying services that won't cost an arm and a leg?
Reply 8 of 29, by weedeewee
Wasn't there a guy on here that already built his own quad Voodoo whatever card? Same guy that did the AGP-PCI or PCI-AGP thing I think...
Do not ask Why !
Reply 9 of 29, by TelamonLivesOn
weedeewee wrote on 2021-04-09, 21:36:
If you are talking about the Quantum3D brick, he didn't design it but rather assembled an existing one, along with replacing faulty components.
If you are talking about anthony's Voodoo 6000 replica, that uses VSA-1000 chips, not SST-2 ones.
Reply 10 of 29, by weedeewee
TelamonLivesOn wrote on 2021-04-09, 21:40:
I was thinking of sdz from what he wrote in this comment.
Re: AGP to PCI adapters - any PCB designers here willing to make one?
Do not ask Why !
Reply 11 of 29, by sdz
I should have scans, and some dxf files. They are quite high res, and the dxf files are huge, where should I upload them?
Reply 12 of 29, by TelamonLivesOn
sdz wrote on 2021-04-09, 22:42:
Google drive or dropbox would work fine.
Reply 13 of 29, by sdz
https://drive.google.com/file/d/1Z3agg_YqD1w0 … iew?usp=sharing
Innovision card, it had a ripped TMU (& pads) and was quite unfixable. This link might also help, check first posts: Voodoo2 component map + schematics
I should have a dxf file with the top layer, and scans of the internal layers, but I can't find them right now.
Reply 14 of 29, by TelamonLivesOn
sdz wrote on 2021-04-09, 22:53:
If you find the internal scans, let me know. This would greatly help me with the creation of my own card(s).
Reply 15 of 29, by TelamonLivesOn
One question I have is why does the remaining Voodoo 2 Documentation say that the TMU and FBI chips support SDRAM? I thought that was introduced on the Banshee/Voodoo3. Is this datasheet even real or fake: http://ohwc.narod.ru/video/3dfx/v2_voodoo2_spec.pdf?
Edit: The specs for the Voodoo 1 look similar, but mention EDO ram instead of SDRAM/SGRAM. They also have no references to 2D whatsoever.
Edit 2: If the Voodoo 2 chipset does indeed support SDRAM as an alternative to EDO, then this changes everything.
Reply 16 of 29, by TelamonLivesOn
Anyone know?
Reply 17 of 29, by sdz
"Important Note: Throughout this document, features, descriptions, and specifications which are marked withthe * symbol are not present in the Alpha version of the Voodoo2 Graphics chipset.
Polygonal anti-aliasing*
Ultra-fast full-screen clears using SGRAM color-expansion capability*
Embedded RAMDAC with dual-PLLs for video and graphics clock synthesis* (may be ommitted from spec)
Embedded NTSC/PAL Encoder for direct Television output* (may be ommitted from spec)
2 or 4 MBytes of SGRAM* or SDRAM* frame buffer memory
2, 4, 8, or 16 MBytes of SGRAM* or SDRAM* texture memory"
I don't think SDRAM/SGRAM support ever made it into the final silicon revision, as well as 8-16MB texture memory support.
Reply 18 of 29, by TelamonLivesOn
I wonder if the VSA-100 would fare better for my project, as documentation is much more abundant.
Edit: I should've known the features weren't present, as I know that there is no embedded ramdac.
Reply 19 of 29, by TelamonLivesOn
sdz wrote on 2021-04-10, 21:50:
"Important Note: Throughout this document, features, descriptions, and specifications which are marked withthe * symbol are not […]
The document does not say that 8-16mb was not present in the alpha version, but we won't know for sure unless the actual chip's pins are reverse-engineered (I may create a separate thread for this process later.
