First post, by majestyk
A Trident "TGUI9440-1" PCI adaptor has been bugging me for a while. One time it worked flawlessly, then it refused to output any picture.
Now it seems to have quit working completely.
I replaced the VGA-connector, resoldered all the Video-RAM chips, checked everything carefully under a mgnifying glass - to no avail.
Then I suspected the Video-BIOS to have an issue and thought about reflashing it. But I cannot find the slightest trace of this chip online. Its a "HM53592T".
Video cards are not my strong point at all so I´m stuck here.
663.48 KiB
Any hints / help would be welcome!
Reply 1 of 7, by Tiido
It is a Mask ROM, so you cannot update it or anything.
Reply 2 of 7, by weedeewee
Though... you probably can replace it with a properly programmed eprom .?
Do not ask Why !
Reply 3 of 7, by majestyk
Good to know - thanks!
Then the numbers on the circuit are specifically made for the manufacturer, I suppose. When reading "HMxyz..." I thought of some Hitachi chip. But something would to be found on the net in this case.
The card has started working again out of the blue. I will use it as my test-card in the weeks to come and report when it´s failing again.
Reply 4 of 7, by kdr
Try dumping the video BIOS while the card is in the PC and see if the checksum is correct.
I'm sure you've already tried this, but quite often I can fix intermittent issues like this by thoroughly cleaning the gold fingers using isopropyl alcohol.
Reply 5 of 7, by Ozzuneoj
kdr wrote on 2021-04-12, 23:23:
Or a pencil eraser. Fixed dozens of cards this way. 😀
Reply 6 of 7, by kdr
Ozzuneoj wrote on 2021-04-13, 07:08:
Just don't erase the PCB traces or gold-plated contacts! 😀
I once made the mistake of trying to "fix" some corroded gold card edge contacts using sandpaper. Oops. It did a great job at removing the corrosion... along with all the gold underneath!
Reply 7 of 7, by Imperious
You can get the bios here ... http://www.vgamuseum.info/index.php/cards/ite … dent-tgui9440-1
Then you need an eprom programmer and a 27c256 chip or equivalent.
