First post, by mistermister
I am attempting to set up one of my PCs with 2 ISA soundcards in DOS; a Soundscape VIVO90 and a Soundblaster 16 Value. My intention is to use the SB16 for Soundblaster compatiblity and OPL3 and the Vivo for external midi and Soundscape digital audio. I am having trouble figuring out how to disable Soundblaster support on the Vivo card. The only manuals I find online are for the older Soundscape cards, they reference using SSINIT with an onscreen interface. With my Vivo card SSINIT just reports that the driver is installed, there does not seem to be an option to make changes. There is a file SSCONFIG.INI but I can find no documentation for the settings. I tried changing SBMode to false in thr INI file, but the card still complains if I do not set its Blaster environment variable. When I add the SB16 it requires its own Blaster variable, things seem to be conflicting. If anyone has a manual for the Vivo card or has knowledge of how to do what I am attempting, I would really appreciate the help. Thanks in advance.
