SSH2DOS - Updated for 2021 standards
First post, by fragmentfi
The original SSH2DOS was last updated in 2006 and the protocols and ciphers it uses are outdated and basically it does not work anymore. I've patched the program to be up to date (as of 2021).
The old programs can be still used if the ssh server configuration is changed to allow using less secure connection methods. The patched ones have been tested with the latest Ubuntu (20.04.2 LTS) release and needs to changes to ssh server configuration.
Old protocols and ciphers have been replaced as follows:
diffie-hellman-group1-sha1 -> diffie-hellman-group14-sha256
aes128-cbc -> aes128-ctr
hmac-sha1 -> hmac-sha2-256
I have only tested ssh and scp clients with password authentication. Key based authentication is most likely broken and needs some more work. Other changes to the program are minimal, the goal was just to get it working again with minimum effort.
I'm open for comments, bug reports and improvement ideas!
Source and binaries are available on GitHub:
https://github.com/AnttiTakala/SSH2DOS/
Reply 1 of 20, by kdr
Great work! It'll be nice to have a working SSH client for my systems without mucking around in sshd_config on all the servers...
Reply 2 of 20, by keenmaster486
Yooooooooo thank you! Been hoping someone would do this!
World's foremost 486 enjoyer.
Reply 3 of 20, by mr.cat
Tervehdys Antti 😁
I'm not a DOS user but got curious: What are these DOS versions using as an entropy source?
There is no /dev/random for DOS is there? I know in some other systems there are separate entropy daemons used, and they need to be configured by the user.
Reply 4 of 20, by fragmentfi
Good question. The original implementation only uses rand() for randomness so it really isn't cryptographically secure at all. This could be addressed in the future but I wouldn't be surprised if the implementation has other potential security issues. On the other hand I would not use DOS based systems or programs for anything serious anyway 😁
Reply 5 of 20, by mr.cat
Thanks, that's pretty much what I suspected. You're right it's more of a convenience to provide connectivity to modern machines, not really for security.
Hopefully the potential users are aware of that.
Anyways, nice to see that even the humble ole DOS hasn't been left behind 😁
Reply 6 of 20, by Hojo82
This is awesome! I got bitten by the old cipher issue in the past couple of months, so this is a welcome update! 👍
Reply 7 of 20, by fragmentfi
There is now a release package on GitHub for the initial release.
Something to note: the non-386 versions are slow. The process between starting the program and prompting for a password takes 11 seconds on my 266MHz Pentium II when connecting to a machine in the same network. For the 386 version it takes only about one second. As I currently only have Pentium class DOS machines, I'd be interested hearing some feedback and test results from slower machines.
Reply 8 of 20, by keenmaster486
fragmentfi wrote on 2021-04-15, 16:38:
I can attempt this later today on my 286.
Reply 9 of 20, by Stiletto
fragmentfi wrote on 2021-04-15, 10:21:
Time for the return of the lava lamp entropy generator? 😁
do the Fandango!" - Queen
Stiletto
Reply 10 of 20, by Axatax
Thanks for doing this. I use SSH2DOS, and it'll be one less inconvenience to deal with every time I upgrade my Linux systems.
Reply 11 of 20, by keenmaster486
So I tried this, and after waiting several minutes, it never did give me the password prompt. Not sure if it ever would have if I had simply continued waiting. Either way it is just too slow to be usable.
Reply 12 of 20, by fragmentfi
Thanks for testing. I haven't had any time to work on this recently but my plan is to add a faster (but way less secure) method as an option. Also I now have a 33MHz 486 setup to test with.
Reply 13 of 20, by HandOfFate
Thanks for updating the client fragmentfi!
I usually start a FTP server for incidental file transfers but using SSH will be much more convenient.
Stiletto wrote on 2021-04-19, 05:59:
Or input noise from poorly shielded microphone inputs 😜 (although I believe reading that fans and other repeating things nearby also make such noise somewhat predictable)
Am486 DX4 120MHz, no L2, 16MB, Tseng ET4000/W32 1MB VLB, ESS ES1869 /// 5x86 133MHz, 256kb L2, 64MB, S3 Virge/DX 4MB PCI, SB16 + Yucatan FX, PicoGUS /// Pentium III 1GHz, 512MB, Asus V7700 64MB AGP, SB Live!
Reply 14 of 20, by ajacocks
This is definitely useful for management of DOS-based systems in my house. It’s always handy to be able to easily reach back to my servers to grab information, easily.
- Alex
Reply 15 of 20, by radiance32
fragmentfi wrote on 2021-04-14, 18:40:
The original SSH2DOS was last updated in 2006 and the protocols and ciphers it uses are outdated and basically it does not work […]
Hey fragmentfi,
Since performance will be crucial for your SSH implementation on DOS systems with slow 8086/186/286 CPUs, here's something you can try to speed things up:
I've come across a very nice, extremely simple implementation of the XOR shift register (Xoshiro) type of random number generators that produces random numbers "nearly as good" as CPU intensive LCG (Linear Congruential type) RNGs,
and better random numbers than rand() (and faster too).
I've been writing an unbiased path tracer (a sort of GI ray tracer) in MS-DOS during the last few weeks for an upcoming video on my 200LX YouTube channel,
and since path tracing requires lots of random numbers (just like SSL encryption does in your SSH2DOS) and requires an RNG with good periodicity and high quality "randomness",
I initially used an LCG similar to linuxs' rand48() with good, but slow results, as there's more than a dozen multiplications and additions per number in the function.
After switching from the LCG to this XOR shift register RNG I've got nearly identical quality random numbers with a high periodicity and no observable patterns (int32_t only though, but that's enough as my renderer uses single precision floats throughout),
but my engine speed increased from 49 minutes to 31 minutes per frame! 😀, with identical quality results. I'm using the Borland C++ 3.2 IDE and compiler/linker for MS-DOS.
For security reasons you might want to leave the current RNG in there (or add a better one like an LCG), and maybe add a command line option to use the RNG you already use, or the LCG, or, this one, so users on slow systems like PC/XTs can use the command line switch to use this XOR shift RNG to get a nice speed boost... (although with less security, but you can't have it all 😀 )
It's really simple too, only 3 bit shifts and 3 XORs on an unsigned 32bit integer, here's the function:
// Fast Xor Shift 32bit precision RNG
static uint32_t _fXorState = 2171454626; // RANDOM SEED & STATE
inline uint32_t fXOrShift32(void)
fXorState ^= fXorState << 13;
fXorState ^= fXorState >> 17;
fXorState ^= fXorState << 5;
return fXorState;
With old C/C++ compilers on DOS, with a 16 bit target, you'll have to typedef uint32_t as an unsigned long int, but I'm sure you know that already 😀
The 80186 CPU (HP 200LX) does multi bit shifts 3x to 4x faster than a 8086/8088, as does the 80286,
so it's even better on those platforms...
All you have to do is find a good way to get a good random seed (_fXorState ) for the RNG...3
Cheers,
Radiance
Check out my new HP 100/200LX Palmtop YouTube Channel! https://www.youtube.com/channel/UCCVChzZ62a-c4MdJWyRwdCQ
Reply 16 of 20, by radiance32
I will also test it out this weekend on my 200LX palmtop, it's a double speed (16MHz 80186),
so it should be a good test for REALLY old/slow machines...
Cheers,
Radiance
Reply 17 of 20, by kpmgeek
radiance32 wrote on 2022-06-24, 08:39:
I will also test it out this weekend on my 200LX palmtop, it's a double speed (16MHz 80186), so it should be a good test for REA […]
Cheers,
Radiance
Did you or anyone else ever get around to trying this?
Wondering if there's been success on non-386 machines and what handshake times were like. Wondering if I can just get away with putting a picomem with wifi in my 12mhz 286 portable rather than a Zimodem based thing doing its own ssh handling.
Reply 18 of 20, by digger
Thanks for maintaining an SSH client for DOS. 😃
As for finding a proper source for the randomness: perhaps you could detect whether the system has a sound card installed and if so, try to use the background noise of the microphone input?
I get that it's a bit creepy for an SSH client to access a computer's microphone, of course. 😁
The X and Y values on PC game ports also tend to fluctuate, so that might be a source too.
Alternatively, allow the option of providing SSH2DOS with a seed file generated on another (more advanced) computer. Have SSH2DOS use the last line of entropy and discard that last line from the seed file on each run. Once the seed file is empty, show an error that a new one should be provided.
Or maybe just ask the user to provide entropy by typing in some random characters or moving the mouse a little, each time SSH2DOS is run?
I'm sure that others can come up with solutions as well. 🙂
Reply 19 of 20, by digger
By the way, does SSH2DOS support ed25519?
