First post, by Wsamuel3
Fullscreen has stopped working for me. It flashes on and then reverts to a DOSBOX Status Screen. I have tried updating and rebooting, but nothing helps. The regular screen shows up in such miniature on my PC that I can't really use it. I am on a Windows 10 PC.
Bill Samuel, Rockville, Maryland USA
Reply 1 of 2, by Wsamuel3
I got it fixed by uninstalling a recent program I had installed - Discord (a discussion platform). Everything works fine since I did that. There probably should be a list of programs which can cause problems with DOSBOX.
Reply 2 of 2, by DosFreak
There may be an option in the discord settings to disable the overlay. Sounds like it takes focus away from DOSBox.
You can also try changing the DOSBox Output= in dosbox.conf to a different value
Make your games work offline
