First post, by SBB
Hi all
I know its not THAT retro hardware but it's getting there ... I suppose! I have a strange problem with a PC i've built and not sure where else to ask,
Other than this problem it works OK and is stable,
Specs:
Intel Core 2 Extreme QX6700, MSI P35 Neo2 motherboard, 4GB Corsair Dominator PC8500 DDR2,nVidia 8800 Ultra, Aerocool Cylon 600W PSU
If the PC is unplugged from the mains, and then I switch it back on again, I get the error that the BIOS settings are incorrect, press F1 to enter setup or F2 to restore defaults. It hold the settings fine when powered down but left plugged in.
I've had this happen in the past when the CMOS battery is flat (this motherboard is probably coming up to 15 years old after all). I put a brand new CMOS battery in but it still happens
I tried updating the BIOS to the latest version from the MSI site, didn't solve the problem
Had a look around on the motherboard for any clear CMOS jumpers that might be set to the wrong position. This board has a clear CMOS button so I couldnt find any problem there
Any more ideas? I'm a bit stumped
Basically it works fine but it's really annoying to have to input the BIOS settings every time I turn it on
Reply 1 of 2, by RichB93
Are you sure the replacement battery is good? Are the battery contacts clean? They'd be good first steps to take.
Reply 2 of 2, by weedeewee
SBB wrote on 2021-04-20, 14:49:
When your computer loses the settings, does it also lose the date & time ?
Do not ask Why !
