First post, by Old_Jelly
Hey guys !
I got myself a ASRock 4CoreDual-SATA2 motherboard and had an idea of making a test system where I can test my retro graphics cards AGP or PCI-E in one place.
511.09 KiB
So I put together a Q6600 ( looking for a QX6700 & QX6800 ), 2 Gb of 533 Mhz DDR 2 memory, Crucial BX500 480Gb SSD, Kolink Enclave 500W Gold MPS, Creative X-FI Xtreme Gamer sound card.
The system is running Windows XP SP3
275.45 KiB
As I have a Geforce 6800 Ultra AGP and a Radeon X850 XT PCI-E I wanted to try out my new system I put together.
Drivers are: Geforce 93.71, Radeon 10.2
(Please note however that the PCI-E slot only works on x4 and I hope there aren't any big bottlenecks because of that)
If someone has the time and a X850 XT PCI-E I would appreciate if you could do the same tests with X16 bandwidth to see what and if there would be any major differences.
Now for the benchmarks:
3DMARK2003 (default)
3MARK2005 (default)
D00M 3 1280x1024, Ultra Detail, No AA
F.E.A.R. 1024x768, Maximum
3DMARK2003
250.41 KiB
3DMARK2005
250.54 KiB
D00M3
24.94 KiB
Reply 1 of 12, by Old_Jelly
F.E.A.R.
151.02 KiB
RADEON X850 XT PCI-E
3DMARK2003
251.16 KiB
3DMARK2005
250.86 KiB
D00M3
30.91 KiB
F.E.A.R.
135.91 KiB
Reply 3 of 12, by framebuffer
Nice board, has some annoying things but still one of the best options if you need a fast CPU for AGP.
anyway, if " test my retro graphics cards AGP or PCI-E" means testing cards you already know are good and you want to check performances etc. that's fine, on the other hand, if you mean testing untested cards, I'd avoid using the 4CoreDual-SATA2 because sometimes things can go very bad with untested hardware and this ASRock is somehow precious, would be unfortunate lose it for a faulty video card
Windows 98 and SAMBA | Quake CPU Benchmarks | GeForce2: GTS vs MX400
Reply 6 of 12, by H3nrik V!
dataino.it wrote on 2021-04-26, 17:09:
After an AGP killer killed my QDI motherboard I wanted to buy this, https://it.aliexpress.com/item/702916303.html […]
is there you know for PCI too?
Can't really figure out, what that piece of hardware would do. Could you clarify?
Reply 7 of 12, by dataino.it
H3nrik V! wrote on 2021-04-27, 05:43:
I simply have a box of untested video cards to check and possibly repair. I can't risk a motherboard every time I plug a card into the BUS
Reply 8 of 12, by RandomStranger
Maybe it's a dumb question, but should you go this far with a test system?
Mine is just a motherboard on a mobo tray I drilled out of a banged up ATX case. At most I'm thinking about riveting a drive caddy from another banged up case to the underside and adding some legs.
Reply 9 of 12, by dataino.it
Sorry maybe I went OT, I reconnected to the messages asking you if the video cards were known as good, and I wanted to report that the risk of inserting an unknown card into the system
Reply 10 of 12, by LHN91
Used to have one of these boards, which was formerly my in-law's business PC, and then I was planning to use as a spare machine, and then as an XP box..... It was always just a bit unstable. It had a Q6600 on it, and I'd be leery of going any higher than that just due to the stability issues.
Reply 11 of 12, by havli
VRM on this board is rather weak. I definitely wouldn't run C2Q here. 45nm Pentium or Core 2 Duo is much better. Runs very cool and also faster... unless you really need 4 cores.
Reply 12 of 12, by H3nrik V!
dataino.it wrote on 2021-04-27, 06:43:
So, it is a tester of some kind?
