First post, by framebuffer
- Member
Hi Falks,
Lately I worked on a little project where I decided to test my GeForce 6800LE card to see how many pp/vp can be unlocked and how far the card can be overclocked.
I then decided to add the Radeon X800SE to the project; it has no unlockable pipelines but it can clock very well and it's from the same generation, so it's kind of interesting.
At the end the 6800LE managed 354MHz / 730MHz w/ 12pp/6vp (from 300MHz / 350MHz w/ 8pp/4vp)
The X800SE (8pp/6vp) managed to get up to 555MHz / 1110MHz (from 425MHz / 400MHz )
Here are few tests
I kind of skipped these cards back in 2004 because I had the X800PRO VIVO with @XT BIOS-MOD, but the performance improvements are pretty interesting I think!
Will do a full compare/review at some point
If you want to check the full article is here: https://framebuffer.io/project/project-6800le-x800se
