First post, by MT32!
Does anyone have a file they could share?
Reply 1 of 10, by appiah4
Do a search for Snark Barker on Google, that project has one on the github page.
Reply 2 of 10, by MT32!
appiah4 wrote on 2021-04-26, 06:20:
Those volume knobs are not the correct size. I am having a hard time believing no one has made this
Reply 3 of 10, by appiah4
MT32! wrote on 2021-04-27, 04:25:
Those knobs are the exact correct size for a SB 1.5
Reply 5 of 10, by MT32!
Thermalwrong wrote on 2021-04-27, 10:13:
The .zip file attached in this thread seems to be the right size for a CT1740 / CT1600, I haven't seen it uploaded anywhere else: Re: Anyone make a 3d printed volume wheel for the older sound blaster cards yet?
tried it but will not work because the back side is not the same where it attaches to the pot.
Reply 6 of 10, by Thermalwrong
okay, I'll make a model of the wheel from my CT1600 and post it up on thingiverse. I see what you mean I think, the underside is inset where the pot fits and the wheel sits over it somewhat when it's installed, instead of just on top of it.
Reply 7 of 10, by MT32!
Thermalwrong wrote on 2021-04-28, 10:23:
Thank would be awesome !
Thanks alot will print it right away
Reply 8 of 10, by Thermalwrong
Here's a version that I've modified to fit the CT1600 / CT1740, it turns out the potentiometer has a slightly larger cam at the top compared to the CT1320.
My CT1600 has a 5mm/4.5mm x m1.6 screw in there, which works with this design too.
The attachment 2021-04-29 23_20_01-PrusaSlicer-2.3.0 based on Slic3r.png is no longer available
I hope it works for you 😀
My test prints are printed at 0.1mm layer height using PETG with the 0.4mm nozzle, so you can print this without any special settings or smaller nozzle.
Reply 9 of 10, by MT32!
Thermalwrong wrote on 2021-04-29, 22:54:
Here's a version that I've modified to fit the CT1600 / CT1740, it turns out the potentiometer has a slightly larger cam at the […]
thanks printing it now will let you know , looks like it should work
Reply 10 of 10, by MT32!
worked thanks!
