First post, by Unregistered
Unregistered
Offline
I Installed vdmsound on WinXP SP1 as administrator and try to start it as a regular user now, but every time I get an error saying that a quicktip could not be found. It's not a problem with permissions because if this user is added to the administrators group, the same problem occurs. It doesn't happen if vdmsound is started as administrator.
Andreas
