First post, by vkcpolice
vkcpolice
Offline
Hi all im trying to restore a Dell Optiplex GX1 it has a faulty floppy drive that i want to replace but im having a hard time trying to find one.
it needs a special type so the case button can push up against the drive to eject the disk but all my floppy's i have laying around do not fit and are not suited.
i have tried looking on ebay with no luck does anyone know if there is another generic type of floppy that i can use?
i will post a pic soon with the current drive so you can see the type im after it needs a flat eject button when you remove the face plate
