First post, by Mephisto
Hi every1 , i have a little problem and maybe some of you has some experience with such thing ??
OK : I want to make a MS-DOS BOOT-CD with Nero 5.5.10.xx,i have the Dos-Bootdisk, and its easy to make it with only the boot disc using, but i want to put some games on this cd too (cause i think that 1,44 mb is a waste for a 700 mb cd) -
Could someone write it point by point how to make such a boot-cd ??
( Or is it enough to copy only the IO.sys / Msdos.sys & command.com on this cd bo be a bootcd ??? - just like to create a boot-disk in msdos ??? )
To the MS-DOS envoirment :
I have only the drive A: for floppy and the C: drive , witch is FAT 16 formated - two cd-rom drives
Im using the "crusader boot disk" with this beehive dos on it but i think i will change it to my MS-DOS 6.22
Why i wanna make this disk: cause my floppy drive is making strange noises 😖 and i think its can crash anyday. so i need a "bootdisk" for my ms-dos games 😁 😁
