First post, by AnnoyingPentium
Hi there.
As the title suggests, I have a Toshiba Tecra 510CDT running Windows 95 with absolutely NO (zilch, zero, nada, etc.) sound drivers for the built in Crystal CS4232 sound chip. I tried using the ones from Toshiba's website but it wanted to decompress to a floppy disk using a variety of things I didn't quite understand fully. I also tried the ones for the ISA card and they didn't let it show up as a sound device either. If anyone has any help (or drivers, please 😀 ) then it would be greatly appreciated!
Regards,
AnnoyingPentium
That sounds irresponsibly silly and is therefore, clearly, something I am likely to almost always do.
Reply 1 of 1, by Thermalwrong
Try out these ones, they're from the tecra 500CDT pre-load disc that came with my 500CDT, it's got the same CS4232 soundchip.
You could also try drivers for the Tecra 720, 730 & 740 laptops, they have the same soundchip, though I Think they may also require a floppy to load up.
