First post, by appiah4
While desoldering a damaged ISA slot from my GA-686LX motherboard I accidentally damaged an SMD capacitor (I think).
The IC in question labelled BC1 is connected to Pin 40 (Vdd) of the KBC on one end and GND on the other. I need to replace it but have no idea what it is.
It's apparently a decoupling cap, but I don't know what the value should be. My gut feeling is something like a 0.1uF part, but I'd like to know if anyone can confirm..
Reply 1 of 2, by Horun
Sorry do not have that board and none match. Is that the SMD cap near the corner of the KBC ?
If so am sure near any low capacitance (less than 0.01mFD) would work. Closest is on a Pentium board with similar AMI-Key KBC and is a 104 (100nF) off the same pin.
Maybe someone else has a more similar board....
Reply 2 of 2, by appiah4
Horun wrote on 2021-05-03, 02:57:
It is exactly as you describe, at the edge of the board next to the KBC and connected to Pin 40, and (I think) an 0805 package. This is enough confirmation for me, I'll just slap on a 100nF and see how that goes, thank you so much.
