First post, by brian105
I'm slowly upgrading the parts of my Presario 5284, and the Bigfoot drive is just... *eugh*. Needs to be replaced for something faster. I was thinking of grabbing some cheapo 16GB or 32GB SSD from eBay, but since most are SATA, I need to figure out how to connect it. I looked into 2 choices: an adapter for SATA to IDE, or a standard PCI SATA controller, and neither seem bad.
However, I can't find a cheap SATA to IDE adapter which doesn't cost more than the SSD itself or come from China with 12 year shipping.
SATA controllers are cheaper, but I'm not sure of the performance implications; will it be slower than just using an adapter? Will it affect the performance of other PCI-connected devices since PCI is a shared bus?
For reference, the PCI stuff connected currently is the GPU (GeForce4 MX 440SE), the onboard USB 1.1 ports on some sort of riser, and (possibly) the integrated 10 mbit DEC Ethernet.
OS that will be used is 98SE/DOS if drivers could be a concern.
Thanks for any advice.
Presario 5284: K6-2+ 550 ACZ @ 600 2v, 256MB PC133, GeForce4 MX 440SE 64MB, MVP3, Maxtor SATA/150 PCI card, 16GB Sandisk U100 SATA SSD
2007 Desktop: Athlon 64 X2 6000+, Asus M2v-MX SE, Foxconn 7950GT 512mb, 4GB DDR2 800, Audigy 2 ZS, WinME/XP
Reply 1 of 24, by cyclone3d
What is the max size of drive that the BIOS on the motherboard supports?
That will determine whether you want to go with an IDE to SATA adapter or with a PCI SATA RAID card.
I use the Chinese IDE to SATA and IDE to M.2 adapters and both work just fine.
Sure they take a few weeks to arrive, but if your motherboard supports big enough drives or if you don't mind using a drive overlay software then that is the way to go.
If you do get a PCI SATA card, make sure it is a SATA 1 card as you will not find any real SATA II PCI cards with Windows 9x drivers so you will be stuck in compatibility mode in Windows 9x.
The best ones to get are the Promise SATA 1 RAID cards as they have the BIOS and also have Windows 9x drivers available.... except for the really high end ones with a RAM slot for cache.
Maxtor also rebranded them but they are the same exact Promise chipset.
Yamaha XG repository
YMF7x4 Guide
Aopen AW744L II SB-LINK
Reply 2 of 24, by brian105
cyclone3d wrote on 2021-05-04, 07:13:
I'm not certain what the max size is, though I'll be going below that likely (16gb is the most common cheap drive on eBay, stock drive with the machine is 19gb) I might go for a 32GB drive if it's cheap enough. Can you link the SATA to IDE and/or m.2 to IDE adapters you bought?
Reply 3 of 24, by dionb
Win98 drivers aren't the only challenge for a SATA adapter, it also needs to work on a PCI 2.1 bus without 3.3V.
As that's a card design thing rather than something to do with the chip, it's difficult to give generic recommendations, but one range of cards almost certain to work is the Promise SATA150-series (TX2Plus, TX4). They also have Win98SE drivers.
Reply 5 of 24, by dionb
Brickpad wrote on 2021-05-04, 14:57:
Does SATA even use 3.3v anymore? Or is this a concern with the older cards / drives? I'm finding most cables only have 5v and 12v + GND.
It's not about the SATA drive itself (which you don't power from the controller card anyway), just the PCI card. Same issue as with some Ethernet cards (RTL8139D-based) and USB 2.0 controllers.
Reply 6 of 24, by brian105
I found these two SATA to IDE adapters on Amazon for $10:
https://www.amazon.com/SinLoon-Female-Adapter … /dp/B07TPBC34F/
https://www.amazon.com/GODSHARK-Adapter-Drive … /dp/B07R4TLBQJ/
They look identical, but reviews seem good for both (besides the complaints that the IDE connector is flipped upside down... really?)
I looked for Promise SATA150 cards on eBay, but all I found were SATA300 cards and SATA II 150. Not sure if those will work as well, though they are a bit more expensive ($20)
Reply 7 of 24, by weedeewee
While you might be one of the lucky ones that get good results with those adapter...
you might want to get this one
https://www.startech.com/en-us/hdd/ide2sat2 https://www.amazon.com/StarTech-com-Drive-Opt … NGC2/ref=sr_1_3
It has a marvell Chip
Do not ask Why !
Reply 8 of 24, by mothergoose729
brian105 wrote on 2021-05-04, 17:23:
I found these two SATA to IDE adapters on Amazon for $10: https://www.amazon.com/SinLoon-Female-Adapter … /dp/B07TPBC34F/ https: […]
The promise cards all work under IDE emulation. You don't even need drivers and they are very, very fast for win98. I was using the SATA 150 card and I saw speed of around 120MB/s.
Reply 9 of 24, by brian105
So the SATA II/SATA 300 cards should work fine? They're around $15 on eBay.
Reply 10 of 24, by mothergoose729
Both the TX2 and TX4 have official driver support for windows 98. I would guess that they will both run at the same speed though regardless, but the 300 series might be faster. I have seen both cases - SATA II devices that function as SATA 1 speeds and sometimes SATA II devices that get most of the SATA II speeds. Not that you are likely to notice either way.
Personally I own a SATA TX2 promise card and I have had some success with it on my 440BX board.
Reply 11 of 24, by brian105
Unfortunately I can't find any cards which are supported under 98 (SATA 150 tx2+/tx4 and fasttrak s150 tx2+/tx4) for a normal price. But I've heard that these cards had OEM variants which are basically the same but named differently. Does anybody know the model numbers for some of these OEM variants?
Reply 12 of 24, by Horun
Nope do not know what the OEM variants are. What is a normal price for ?
Have you figured out how to mount in the case to replace the Bigfoot ? just curious....
Reply 13 of 24, by mothergoose729
brian105 wrote on 2021-05-05, 02:05:
I did a quick ebay search and found a ton of TX4's that were pretty cheap. You can also get an ultra ATA IDE controller instead.
I imagine there are other SATA controller cards that will also work. The promise cards have officially drivers but you don't actually need them. What matters is that the controller can do "legacy" or IDE emulation, which many of them can.
Reply 14 of 24, by brian105
Horun wrote on 2021-05-05, 02:50:
Probably gorilla tape, the best way to mount SSD's (TM). As long as I don't jostle the case around a lot, it should stay in place.
mothergoose729 wrote on 2021-05-05, 02:51:
Are you sure they weren't SATA II 150 TX4's or SATA 300 TX4's? I saw a lot of those, but no SATA 150 TX4's.
Reply 15 of 24, by cyclone3d
The Promise Sata 1 cards are not showing up as much as they used to. Just keep an eye out and you should be able to snag a few for cheap when they do pop up.
YMF7x4 Guide
Reply 16 of 24, by Repo Man11
Promise Ultra 100 cards are still readily available and pretty inexpensive - combined with a SATA adapter, you'll still probably spend less than you would for one of their SATA cards. While I was lucky enough to get one of the cheap Sil3114 cards to work in a Socket 7 system, it gives errors when I try to use it with my Epox MVP3G-M, but the Promise card never fails to work. Here's a Promise Ultra 100 combined with a no name SATA adapter and an old intel SSD.
Reply 17 of 24, by Repo Man11
Here's the Sil3114 on my TXP4 with a newer SSD. Probably the main advantage is less clutter since you use the SATA cable from the card to the drive rather than an IDE cable to the adapter.
Reply 18 of 24, by brian105
I managed to snag a card for $20 including shipping. It's not exactly Promise, but it's an OEM branded one (Maxtor SATA/150 PCI). It has the same chipset on it, and checking driver support reveals that it does support Windows 98. I've attached a picture of it (really awful picture from the seller) and the drivers to use for later.
    sata_card_driver.exe
    306.5 KiB
    39 downloads
    205.92 KiB
Reply 19 of 24, by dionb
brian105 wrote on 2021-05-05, 18:35:
That looks suspiciously like a rebranded SATA150-TX2Plus. Fingers crossed it works just like the original 😀
