First post, by Unregistered
G'day All,
VdmSound is great. Works with practically all my old games with only minor tweaking. But I'm having problems with the game Siege by Mindcraft. The game only works if I select "No Sound" and "No Music" in the installation program. If I try running it with sound, i.e. Using the default soundblaster settings, the install program tells me that I don't have a soundcard connected or that it can't get the DMA setting to respond.
If I select to use "Adlib", the program still responds by saying it can't access the DMA, but the game will play with music but no sound effects. The game runs fast but I'm trying to get the sound to work first before I start playing around with Speedset and the like.
I've downloaded the latest Vdmsound and also Launchpad plus the update. I've tried playing around with all the soundblaster and adlib settings as well as changing the DMA polling. I have the original game on floppies but I've also downloaded the version off The Underdogs site in the hope that it was just my version, but it doesn't work with that one either.
Any help would be greatly appreciated.
Computer Specs:
Asus7V motherboard
AMD 900MHz
392MB RAM
Asus GeForce2 MX 32MB
Hercules MuseXL
WinXP
