First post, by MRVFONE
Hello,
I'm trying to repair a SC-88 that won't boot. (file attached of screen)
I did the 240V conversion.. and thats working fine.... I re-caped the program board as the caps were leaking. But its still stuck on the same screen. New coin cell.. same thing as well.
Does anyone have a dump of the progam rom?? So i can program a eprom replacement incase thats faulty??
Thanks,
T.
    82.47 KiB
Reply 1 of 6, by cyclone3d
I would look for corroded traces on the main board since the caps were leaking. I'm dealing with the same kind of problem on my SC-88 but it actually boots but doesn't play any sound from the synth.
The memory diag shows to check a bunch of stuff but, upon closer inspection, there is a bunch of corrosion on the main board from the leaky capacitors so I am going to work on fixing that and then hopefully it works.
Yamaha XG repository
YMF7x4 Guide
Aopen AW744L II SB-LINK
Reply 3 of 6, by MRVFONE
If someone has a SC-88 PRO and they want to dump the Program ROM for me. Its IC 26. Socketed. And should be dumped as a ST M27C800 eprom. I have checked the pin out between the SC-88 PRO tech manual and the 27C800 datasheet. And they are a 100% match.
Thanks again!
T.
