First post, by digicube
Is it possible to do a linux dd in Windows?
https://www.ibm.com/support/pages/how-view-co … ape-tape-header
Reply 1 of 8, by Caluser2000
https://serverspace.us/support/help/dd-utilit … windows-backup/
Or get to know how to use Linux or similar *nix OS. It comes in useful at times.
Reply 2 of 8, by Zup
It may be easier to boot a live CD (Puppy Linux?) and do the dd on Linux.
I'm selling some stuff!
Reply 4 of 8, by Zup
AFAIK, you can't use a disk editor on a tape drive...
Reply 5 of 8, by Caluser2000
man dd
Reply 6 of 8, by digicube
Windows drivers for vintage tape drives are hard to find, I assume Linux ones would be impossible to find unless Linux natively supports all vintage tape drives. Does modern Linux distribution still have this dd command for tape drives? Or do I need to find a legacy distribution?
Reply 8 of 8, by megatron-uk
digicube wrote on 2021-05-11, 05:20:
If the drive is supported (is it SCSI? USB? IDE?) then dd will work with it as long as the driver exposes it as a block or character based device.
The 'dd' command itself just works with blocks - any device exposed in that standard way can be used with it - it doesn't need to know any of the physical properties of the drive itself.
Of course if you have something fancy like an autoloader library, it won't know about that or tape change commands, but once a tape is loaded/selected it should work with it quite happily.
https://www.target-earth.net
