First post, by DoomSlinger
Hi, I'm trying to set up a midi emulator (as shown in Phil's video here: https://www.youtube.com/watch?v=zRyPjvbDkvg) and am having issues with output. I have an es1869 in my retro rig, but it's integrated into the motherboard, and doesn't have a joystick port. I have a Gamecard III automatic installed in this computer so that I can use an old joystick with it, but I'm not sure if it will allow me to output a midi signal (or at least I haven't gotten it to work so far). If anyone knows anything about getting these working as midi outputs, that would be a huge help!
Reply 1 of 7, by imi
no, there's only a joystick interface on the gamecard, you'd need a seperate midi card like the PC-midi musicquest clone or similar, or just an additional soundcard and just use the MPU interface on that.
maybe there is a pin header for a joystick/mpu port or a midi out on the motherboard?
Reply 2 of 7, by DoomSlinger
I didn't see one, but I may just not know what to look for.
Reply 3 of 7, by imi
well what motherboard is it?
Reply 4 of 7, by DoomSlinger
I don't have the exact model number, but it's for a compaq deskpro en p550 minitower. Here are some pictures of the board and the part stickers.
Reply 5 of 7, by cyclone3d
From what I could find, there is no gameport / MIDI port on the Deskpro EN series.
Sooooo.. here is a crazy idea, or maybe a not so crazy idea.
On the Deskpro, use SoftMPU with the serial port.
http://bjt42.github.io/softmpu/
Then on the MIDI emulator machine, use Hairless MIDI <-> serial and loopMIDI:
https://projectgus.github.io/hairless-midiserial/
You will most likely need a null modem cable (serial crossover cable) to hook them together like this .
Yamaha XG repository
YMF7x4 Guide
Aopen AW744L II SB-LINK
Reply 6 of 7, by DoomSlinger
I think it would be easier to buy a new soundcard with the midi out joystick port. So another es1869 (is there a difference between the 1869F and the 1869FC? haven't found anything anything) unless there are compatibility issues I'm not aware of.
Reply 7 of 7, by cyclone3d
Look what is going to be available for sale in about a week. An RS-232 to MIDI adapter that is compatible with SOFTMPU:
MPU-232 : RS-232 MIDI interface, compatible with SoftMPU
YMF7x4 Guide
