First post, by lucasaugustovd
Hello, does anyone know of a small MUS library written in C? I don't care much about how good it sounds as my purpose is to merge the code into a small Doom source-port I am writing, I am aware of fluidsynth, wildmidi and timidity; the later one is somewhat attractive because it has been available since 1995 but documentation for it is non-existent nowadays, and it depends on a somewhat big file in order to work, so something smaller would be really cool.
For now what I have is just a Linuxdoom with proper sound support and the most annoying bugs addressed, that makes it functional and stupidly easy to build and modify, but there are no new features.
Reply 1 of 3, by enaiel
Are you looking for a MUS library, a MIDI library, or a MIDI soft synth? AFAIK, they are 3 very different things. Fluidsynth, wildmidi and timidity are all MIDI soft synths.
* MUSLib is a MUS library in C, but only for DOS.
* TinySoundFont is a small cross-platform C soft synth, but it doesn't support MIDI.
* TinyMIDI is a small C MIDI library for Linux, which you combine with TinySoundFont to get a MIDI soft synth 😀
Hope that helps and best of luck in your DOOM port!
H/W: VIA C3 DOS PC | PIII-S Tualatin Win98SE PC
S/W: VIAFSB FSB Util | VIAXFG SB Config Util
Reply 2 of 3, by lucasaugustovd
enaiel wrote on 2021-05-12, 03:18:
Are you looking for a MUS library, a MIDI library, or a MIDI soft synth? AFAIK, they are 3 very different things. Fluidsynth, wi […]
Thank you for your suggestions, if MUSLib proves to be difficult to port, the other two will certainly save me a lot of work! I am not aware of the of the differences between them so I am unable to be more specific, to clarify, my goal is to have the source-port itself play the MUS files (lumps, format specified in [1], [2], and [3]) that comes with the game so it can finally play music, support for MIDI files is not necessary but modifying something akin to TinyMIDI to become a "TinyMUS" should not be that difficult, I think.
[1] https://moddingwiki.shikadi.net/wiki/MUS_Format
[2] http://www.vgmpf.com/Wiki/index.php?title=MUS
[3] http://www.vgmpf.com/Docs/Format-MUS-MUSForm.html
Reply 3 of 3, by enaiel
Most DOOM source-ports do not play MUS files directly. Instead, they convert them to MIDI files on the fly, and play those via a MIDI soft synth like Timidity, Wildmidi, Fluidsynth, etc. See Chocolate DOOM's MUS2MID.c, for instance. In fact, the Chocolate DOOM source-port would be a great starting place for any new DOOM port, IMHO. Although I currently prefer Crispy DOOM for the few extra features. But these are just suggestions, don't let me stop you from doing your own thing!
