First post, by sangokushi
I recently purchased an IBM ThinkPad 365ED, but the case coating is very sticky. It seems a common issue for old ThinkPad laptop.
I did try using rubbing alcohol to clean it, but it's still sticky.
Just wondering if there is a repair shop can repainting the laptop coating?
Thanks.
Reply 1 of 6, by Miphee
I tried all methods on my sticky rubberized gamepad and nothing worked. I trashed it. Some user said that the only way to repair these is to remove that dipped rubber surface completely. I tend to believe him.
Reply 2 of 6, by Big Pink
I had the same problem with a ScrollPoint mouse. The stickiness came back after trying to clean it with alcohol, so I just opted to remove it with baking soda. Not as nice in the hand, but not a dirt magnet anymore.
I thought IBM was born with the world
Reply 4 of 6, by cyclone3d
Lemon essential oil works very well to remove the coating. You can also use citrus based furniture polish but it takes a lot longer.
It does take a while to get it all off, but once it is all off, you won't have to mess with it ever again.
I've had to do the removal process on quite a few different things.
That dumb rubberized coating will always start to break down eventually.
The only real fix is to remove the coating completely.
Yamaha XG repository
YMF7x4 Guide
Aopen AW744L II SB-LINK
Reply 5 of 6, by wiretap
Remove coating as stated above -- respray with black Plasti-dip if you want an original look and feel. It isn't exact, but very close. I did it to my Logitech G5. Also, the Plastic-dip can be peeled off and isn't permanent.
My Github
Circuit Board Repair Manuals
Reply 6 of 6, by sangokushi
Thanks everyone! I will try the Lemon essential oil + black Plasti-dip.
