First post, by Scythifuge
- Oldbie
Greetings,
Considering that my Ultimate P3 PC may not have any available slots (depending on the final configuration -I'm still hunting down a 2nd Voodoo2 and I'm hoping to get an AWE64 Legacy and thus currently have an AWE32 and an SCC-1 installed and taking up two ISA slots,) it has been mentioned in another thread that I may need a parallel port option in order to connect to my LAN. I am going to be adding a serial modem to the set up, though adding ethernet capabilities is a must. U am using an RCA CF-parallel adapter for hotswapping CF cards for file transfers, though it feels uncomfortable knowing that I am without ethernet capabilities.
The XIRCOM PE3-10Bt was mentioned, though they seem to be expensive. Are there alternatives? I have heard of something called a Plipbox that allows Amigas to connect to the internet via parallel port. I could utilize a USB-Ethernet adapter, though I will then be unable to connect to the LAN in DOS and WFW 3.11.
Thanks!
Scythifuge
