First post, by cyclone3d
So I just received a package that includes some 100v 50/60Hz equipment. Some of the equipment uses wall warts that are rated at 100V 50/60Hz AC.
I did a quick test on a couple of them plugged straight into the 110/120v outlet and then plugged into a variac set at 100v, confimed with my multimeter.
#1 rated at 9v
#1 - 17v DC
#1 with variac - 12.9v DC
#2 rated at 12v
#2 20v DC
#2 with variac - 17v DC
I'm guessing it would not be safe to use them without the variac or without a step down transformer.
These are all for different sound modules and I don't want to fry them by using the stock adapters, or in the case of some of them that have an internal power supply by plugging them straight into the wall.
Yamaha XG repository
YMF7x4 Guide
Aopen AW744L II SB-LINK
Reply 1 of 5, by snufkin
What are they like with a load of some sort (a few hundred ohms maybe)?
Reply 2 of 5, by BitWrangler
Yup, gotta test them under load, usually at least 10% of rated output watts/amps.
Two things I might try to run them and not tie up your variac... put them in series with 100W lightbulbs... or stack 110-220 and 220-110 adapters and see if the losses drop it to 100. Might work even gooderer if you find a 115-220 and put a 230-110 on it... if they're slightly off 2:1 ratios and not just 2:1 and telling you what you wanna hear.
Reply 3 of 5, by cyclone3d
Well... one of the adapters that was sent is a 100-230v wall wart and it puts out almost exactly the rated 12v. I also tested one of my 120v Roland 9v adapters and not under load it was putting out a bit over 12v.
I don't mind using the variac for now as this is the first thing I have actually used it for. The company I used to work was giving away a bunch of stuff when they consolidated with another location and it is one of the many things I grabbed.
I'll see if I can do some under load tests.
YMF7x4 Guide
Reply 4 of 5, by Cyberdyne
Are they switching or transformer PSU-s? And usually deviations in mains voltages are allowed. Today 2,5-5% in developing countries even 10%. but with old hardware you better not risk it.
Reply 5 of 5, by Standard Def Steve
FWIW, I've been pumping 120v through the veins of my 100v N64 for well over a decade without issue. I'm not saying that all 100v devices will be as tolerant, but some (possibly many?) seem fine at the slightly higher voltage.
"A little sign-in here, a touch of WiFi there..."
