First post, by britain4
I’ve got a Toshiba Libretto U100 laptop I’m trying to spruce up a bit, essentially I’ve fitted a SanDisk Extreme 64GB CF card into it with a 50 pin adapter. The machine recognises it fine with the exception that XP only wants to format it to 32GB although sees the full 64GB when formatted externally in a Windows 10 machine.
Regardless of whether the card is formatted externally or in the Libretto, XP recognises the CF card C drive as being removable and also the swap file isn’t functioning, which I suspect are linked. The system occasionally gives the error "Windows created a temporary paging file…" on boot.
Does anyone know if the two above issues could be linked and if so how to mark the CF card as a fixed drive? If not, anyone have any suggestions on the swap file issue?
Thanks!
- 486DX2-66, SoundBlaster 16, Crystal VLB graphics
- P-MMX 200MHZ, PCChips M598LMR, Voodoo 1, AD1816
- PIII 933MHz, MSI MS6119, Voodoo3 3000, SB Live!
- PIII 1400MHz, ECS P6IPAT, Voodoo5 5500, SB Audigy
