First post, by caver99
i have an InnoVision Mighty 3DII V3
its the 8mb voodoo 2
dowa anyone have the driver disk eith in img format or iso format as no matter what i use it get trouble once imin windows 98se
the card is reconised when i install it and it takes the driver i have managed to find on the net but then i am unable to get in to display properties with in windows
i have tried carmageddon witht e 3dfx patch and it works fine so i know the card is working
the system i have is :-
Pentium P200MMX
acer desktop pc socket 7
8gb hdd partitioned as bios only allows 8gb max
soundblaster 16
dos 6.22 and windows 98se
waiting for some compact flash to pci back plane adapters then wil be using cf cards for storage
Reply 1 of 2, by caver99
just plugged into another system which is a p4 running win98 and when i run rollcage 3dfx i get an error _GlideInitEnvirpoment: glide2x.dll expected Voodoo 2. nonedetected
is this a duff card anjd should i return it as only just bought if for £100
Reply 2 of 2, by caver99
ended up sending it back for refund
