First post, by Aebtdom
- Member
Hi, I've recently installed Half-Life on windows 98 and was having a look on how the game was running on my voodoo2 SLI setup using the 3dfx option in the game.
With the net_graph 3 command I wanted to see how the cards would perform on 1024x768.
The game stated that these settings were not supported. After installing WickedGL, it all worked just fine on 1024x768.
Runing the intro I found out that the game is stuck at 72fps.
Running the command max_fps 999 (since max_fps 0 brings the game to zero fps) wil make the game stuck at 100 fps... there is no drop below the 99.5/100fps at any time.
Is there a way to get the game above 100fps?
Thanks in advance for your help.
Builds:
Xp3000+ radeon 9600XT + vd2 SLI 12MB + 512MB + SB live @ WinXP & 98 Dualboot.
AMD K6-3+ 600Mhz+ Geforce 3 Ti 500 + 3Dfx Voodoo 2 12MB SLI + Sound Blaster 32 + 128MB SDR @ msdos / win98.
