Slot 1 water cooling options
First post, by dionb
What do you do when you have already "done it all"?
Watercool it!
Additional reason is that I have an impressive Compaq i840 dual slot 1 board. Wonderful board, but typically Compaq they have it engineered for a proprietary cooling solution, with passive heatsinks on the CPUs and a hood with big fan to cover them. Great, but I don't have the original case. It's not possible to use regular HSFs as the CPU slots are closer together than on a normal motherboard, and the passive heatsinks don't cool sufficiently without the dedicated hood over them. Also I have a big Zalman Reserator in the corner of the room not doing anything sensible at the moment, which is a waste.
So, what am I looking for: some kind of CPU cooling block I can fix onto an SECC2 Slot1 CPU. Back in the day these were rare enough, today pretty non-existent unobtainium. Additional requirement (due to cramped placement) is that the water tubes need to be connected to the side, not to the top.
I was wondering if any other Vogons water cooling Slot 1 CPUs and particularly what kind of water block you are using and how you attach it to the SECC2 CPU module. Experiences with So370 on slockets also welcome - I'd prefer using native slot 1 CPUs (I have a nice pair of P3-866EB) but if there is a much easier way to get things working with So370, in that case I just need to source a second MSI MS-6905 slocket for my dual P3-1000EB FC-PGA.
Reply 1 of 21, by PC Hoarder Patrol
Wasn't aware they ever used a hood / duct system for cooling the standard passive sinks (certainly not on the AP550 with dual 1GHz), and I don't see it as an option in the parts list?
264.22 KiB
Most of the best slot 1 water cooling options I've seen were designed and milled for a specific board layout.
Reply 2 of 21, by Oetker
PC Hoarder Patrol wrote on 2021-06-02, 08:51:
Loving that huge speaker.
Reply 3 of 21, by dionb
Oetker wrote on 2021-06-02, 09:08:
I *do* have that speaker 😀
But regardless, even if Compaq didn't use the duct, I'm not happy with passive cooling performance and I want to use that Reserator.
Reply 4 of 21, by PC Hoarder Patrol
Possibly something like this mod (slocket-based but I guess adaptable to native slot 1, and with both top & side port options)
https://web.archive.org/web/20011120144221/ht … ps197/index.asp
Reply 5 of 21, by cyclone3d
For waterblocks that have the ports on the side instead of the top, just do a search on ebay for....
waterblock
And then sort by price.
There are a bunch of different ones from China that are like that.
You just need to make sure that you match the material of your radiator with the waterblock so you won't get galvanic corrosion going on.
You will also need to come up with your own mounting mechanism but that is easy enough. For slot-1, you could either remove the heatspreader, make some metal straps and then drill and tap the heatspreader to bolt the waterblock in place or possibly even just use some bolts/nuts with washers through the standard cooler mounting holes.
Slot-1 and Slot-A is really easy to adapt to pretty much any type of cooler because of that huge heatspreader.
Yamaha XG repository
YMF7x4 Guide
Aopen AW744L II SB-LINK
Reply 6 of 21, by DundyTheCroc
I have AP550 with 2 CPUs and stock cooling, CPU temp never reaches more than 40 degree C. Water cooling is overkill, you just need one big fan on rear panel and custom made cover.
Reply 7 of 21, by Miphee
Which Reserator model do you have? To be honest it was a failed construction.
80 C° with a 3,2 non-overclocked Prescott @ 100% is outrageous and that was in 2005.
Since it's a hobby project it doesn't really matter anyway, just not worth the hassle for a CPU with 29 W TDP even a small fan can manage.
Reply 8 of 21, by Doornkaat
If you're handy with a saw and drill you can make your own adaptor plate to use a recent CPU waterblock on Slot 1 CPUs.
Watercooling was still very niche on Slot 1 and I have personally never seen a premanufactured cooler. A classmate's older brother had a diy watercooler on his Slot 1 PIII that he made from an SECC2 cooler and ~6-8mm copper pipe. He'd bend the pipe to make a few loops, then he'd cut off the aluminium fins on the cooler and sand it down to a flat plate. He'd then flatten the pipe a bit where he'd want it on the heatsink (leaving the ends round to connect the tube) and solder it onto the aluminium heatsink plate. I think he used an oil cooler from a motorbike as a radiator and an aquarium pump.
Reply 9 of 21, by dionb
Miphee wrote on 2021-06-03, 09:18:
The original one, which isn't great for keeping stuff cool but is for being quiet and looking good.
Then again, 80C with 3.2GHz Prescott non-OC sounds like something was wrong somewhere. I've seen good reviews of that thing getting a 3GHz Prescott down to 33C at load, and 41C at load OCd to 3.6GHz.
I'm expecting little trouble in keeping two P3s under 40C and am even considering adding the video card to the circuit.
Doornkaat wrote on 2021-06-03, 10:54:
I'm awful with plumbing, have had to replace my kitchen floor twice already over the last five years due to leaks, so definitely want to keep the bits water flows through ready-built. Adapter plates sound interesting though. The challenge as I see it is the four push-through pins connecting heatsink to CPU package. Do you have a diagram outlining what approach the adaptor would have?
Reply 10 of 21, by Miphee
dionb wrote on 2021-06-03, 11:10:
Maybe you are right. The first model was excellent but the second model was notorious for overheating here. We even had a huge topic about it because it was ridiculously expensive but it's performance was poor. Anything is possible. To be honest it was way beyond the price range of the average gamer so people relied on (sometimes paid) reviews. I also have to note that it's often over 35 C° (95 F°) here in the summer so that certainly doesn't help.
Reply 11 of 21, by Doornkaat
I didn't but now I do. Sorta. 😅 I drew up some quick scetches using only professional graphics editing software. 😁
If you buy one of those cheap GPU coolers from Ebay (pic1) you'd probably need three additional parts: Two identical brackets (red, pic2) to go into the CPU retention frame and one bracket (blue, pic3) that replaces the black bracket on the cooler.
Obivously I didn't take any measurements but that would be my initial concept.
    108.88 KiB
    pic1
    188.47 KiB
    pic2
    142.47 KiB
    pic3
Reply 13 of 21, by PARKE
The simplest approach seems using a 'clip-on' style SECC 2 heatsink like f.e the Foxconn 135638-003 C:
62.49 KiB
Have the centre fins removed and the resulting surface milled to get the desired flatness for a tight fit with the waterblock. Mounting a block as in the link posted by PC Hoarder Patrol is relatively straightforward.
Reply 14 of 21, by cyclone3d
Why bother with hacking up the original heat spreader? The tdp of these CPUs don't warrant that.
YMF7x4 Guide
Reply 15 of 21, by dionb
Miphee wrote on 2021-06-03, 11:57:
The review I was looking at for the 1 was legit (I know the reviewer), and I managed to buy it for EUR 25. For that price it was "grab first, think of what to do with it later" 😜
Yes, I remember the one summer I spent in Budapest. Fondly, but that was due to other reasons for getting sweaty 😉
Doornkaat wrote on 2021-06-03, 12:02:
I didn't but now I do. Sorta. 😅 I drew up some quick scetches using only professional graphics editing software. :D If you buy o […]
Hmm, yes, I can see how that would work. A bit worried about a copper block with my aluminium reserator though...
Miphee wrote on 2021-06-03, 12:02:
Maybe this will help if you haven't seen it already.
http://www.dansdata.com/senfu.htm
Tnx. Had spotted it earlier, but discarded it because Athlon Slot A used SECC1. However on re-reading it it also mentions SECC2 lower down.
The thing that worries me is reliably ensuring contact when mounted. Particularly with the cheapest aluminium blocks like these:
https://www.ebay.nl/itm/282445758166?hash=ite … ncAAOSwkShY~kQB
So dirt-cheap I can easily buy a couple on the off-chance it actually works in a non-leaking way. But keeping it pressed onto the core is another matter.
Reply 16 of 21, by cyclone3d
That is why you attach the waterblock to the stock heatspreader plate. There is no reason at all with these CPUs to mount the waterblock directly on the CPU die.
YMF7x4 Guide
Reply 17 of 21, by dionb
cyclone3d wrote on 2021-06-03, 21:30:
OK, but how do you attach it? Soldering would probably only give me contact round the edges...
Reply 19 of 21, by cyclone3d
dionb wrote on 2021-06-03, 22:45:
I already said how to up above:
If the radiator is copper, you want a copper waterblock. If the radiator is aluminum then you want an aluminum waterblock. This is to avoid galvanic corrosion which will lead to the waterblock and/or radiator becoming clogged.
YMF7x4 Guide
