Tseng mdram different models
First post, by Nemo1985
Hello, I'm having a question about the mdram.
I have a ET6000 with 2 socketed mdram module they are called: SJ-5-100, they work fine on my ET6000
When I install them on my ET6100 which originally use AJ-5-120 they don't get detected from the ET6100.
The model for both is MD908. I know that 100 and 120 are the ns.
Do anyone knows the difference between AJ and SJ?
168.83 KiB
If the chips are incompatible with each other I can buy the compatible model but if they are interchangable it would make no sense.
Apparently there are ET6000 with the 120 installed: https://i.ebayimg.com/images/g/N5QAAOSwE4tgShYj/s-l1600.jpg
That card is very like the one I have but mine has 100. So I suppose those are pin to pin compatible?
Information on the net are somewhat scarce unlucky.
Any help?
Reply 1 of 22, by Doornkaat
I have had a similar issue. It appears they are incompatible. I have been looking for MD908 AJ-5-120 MDRAM for my Apocalypse 5D for a while now.
Sadly apparently it only ever surfaces at ridiculous prices so I'll have to keep on looking.
Reply 2 of 22, by Nemo1985
Doornkaat wrote on 2021-06-02, 16:17:
Thank you for the confirmation, at what price did you find them?
Reply 3 of 22, by The Serpent Rider
Yeah, both of my cards have 120ns.
Reply 5 of 22, by Nemo1985
Doornkaat wrote on 2021-06-02, 16:39:
15€-35€ each not including shipping.
The cheapest ones I found in Germany were ~20€ each.
That's the same price I found €30 for 2 mdram chips.
The Serpent Rider wrote on 2021-06-02, 16:38:
I wonder if there is any difference on memory clock between the 2 versions.
Reply 6 of 22, by pentiumspeed
That is reasonable price. specialty chips if limited use, will not be plentiful to find and will have bit of price to go with it. Just buy them.
And yes, there are differences, one are 1MB and other is 1.125MB types, so have to match capacity by matching the part numbers to original: MD908 or MD909 are not same.
MD904, MD906, MD908, MD909, MD910, MD916, MD918 and MD920. These are not same. Match what you have MD9xx to new ones.
https://www.xfree86.org/3.3.6/tseng12.html
Cheers,
Great Northern aka Canada.
Reply 7 of 22, by Nemo1985
pentiumspeed wrote on 2021-06-02, 19:06:
That is reasonable price. specialty chips if limited use, will not be plentiful to find and will have bit of price to go with […]
Cheers,
I agree those won't become cheaper as time passes.
That being said the id number is MD908 for both, the differences are the letter and the access time.
Do you know which one is 1mb and which is 1.125?
Thank you.
Reply 8 of 22, by The Serpent Rider
908 = 1 mb
909 = 1.125 mb
909 chips are rarely used outside of cut-down versions without 4 sockets.
Reply 9 of 22, by pentiumspeed
Serpent Rider, curious, if one have pair of MD908 with another pair of empty spots let it be solder pads or sockets upgraded with two more MD908 memory ICs?
Same idea with MD909 upgraded to four chips from two?
Cheers,
Reply 10 of 22, by The Serpent Rider
Yes, but 909 is absolutely useless in 4 chips configuration. Those additional 0.5 Mb can't be used for anything, especially on ET6000 with poor 135 Mhz RAMDAC.
Reply 11 of 22, by Nemo1985
The Serpent Rider wrote on 2021-06-02, 20:14:
908 = 1 mb
909 = 1.125 mb
The thing is that are both labelled 908, I don't know why this thing 909 came out.
The difference is just on the first letter (AJ vs SJ) and the access time (120 vs 100).
That being said with nssi I noticed that the et6000 is detected as 4mb, while the 6100 is detected as a 2,numbers mb.
If i'm going to buy the right model of mdram do you think they are going to work?
Reply 12 of 22, by pentiumspeed
Your is MD908 and stick with this and having 100 with your 120 does not affect the performance as memory clock is fixed in firmware to use 120 and the chip with 100 will be fine at 120. If the other video card has MD909, use MD909.
Where did you get your MD908 with 100 from? I hope this is not from chinese sellers.
Cheers,
Reply 13 of 22, by Nemo1985
I am probably unable to explain myself.
This is my ET6000:
134.94 KiB
It uses the mdram SJ-5-100, when I check with nssi it detects 4mb of memory.
Then if I socket the mdram chips on the et6100 it still detects 2mb and something memory instead of 4mb.
Since the only difference between the mdram used on the ET6100 and the ET6000 is the AJ vs SJ, I wanted to be sure if i'm going to buy some mdram of the right type it will be detected?
I ask because the layout of the et6100 seems cheaper than the other and before throw away €30 I want to be sure.
I don't understand why people keep mentioning MD908 and MD909, they both use MD908.
Reply 14 of 22, by pentiumspeed
I said: your card uses MD908 has to be two more MD908 to upgrade the card from 2.xx MB to 4.xxMB.
Also I said: if you have another card that has MD909 for example, therefore has to be upgraded with two more MD909.
Cannot mix 908 and 909, both are not same.
The timing is set already in the firmware from the start.
The last characters like 100, 120 indicates how long it becomes available on the data lines after address is loaded into chips. If card uses 120, therefore the firmware on it is set up for that timing and if you found chips with 100 to upgrade memory, will work fine still at 120 timing regardless. if card has 100 original, then upgrade 2 more chips with 120, then have issues because the firmware was set for 100 and is too fast for 120.
Cheers,
Cheers,
Reply 15 of 22, by Doornkaat
pentiumspeed wrote on 2021-06-03, 22:19:
I said: your card uses MD908 has to be two more MD908 to upgrade the card from 2.xx MB to 4.xxMB. […]
Cheers,
Cheers,
He knows those things.
He is specifically asking wether buying and installing two more MD908 AJ-5-120 chips will make his ET6100 have 4MB of VRAM.
He has tried MD908 SJ-5-120 before and it didn't work. This is why he was wondering if the MD908 SJ-5-120 is incompatible with his card.
Now people are talking about the capacity (MD809 vs. 909) and speed rating (-100 vs. -120) of the chips which he never asked about.
Reply 16 of 22, by Nemo1985
Doornkaat wrote on 2021-06-04, 05:16:
He knows those things. He is specifically asking wether buying and installing two more MD908 AJ-5-120 chips will make his ET6100 […]
Thank you Doornkaat, I hope this will clarify the situation.
We will anyway discover the truth soon since I ordered the mdram chips.
Reply 17 of 22, by Jager
Dunno about AJ & SJ, but in my experience you can mix 908 & 909, but you cannot mix -100 and -120. Even if socketed are faster than soldered ones. I have ET6000 with 908-100, ET6000 with 909-120 and some spare 908-120 MDRAM. 908-100 + 908-120 didn't work, while 909-120 + 908-120 works fine. I'll check if they are AJ or SJ bit later.
Reply 18 of 22, by pentiumspeed
Wow that highly unusual. Nemo1985 said his card have 120 soldered, added 2 more of 100 and said didn't work. I was puzzled too.
Next thing, SJ and AJ, I have no answer but from my dram research over the year is usually suffix for internal design that changes over the years or package differences
Cheers,
