Magic 3.5" Disk Drive
First post, by Joakim
Buying weird stuff online, its kind of a hobby of mine I guess.
An external floppy drive caught my eye for a few bucks so I bought it. Its connected with parallel port and powered by an dc power supply.
The attachment IMG_20210603_214804.jpg is no longer available
The attachment IMG_20210603_214749.jpg is no longer available
So what is it anyway and what makes it magical? It seems to have been a part of a "Super Wild Card (SMS3201) Backup Unit" you basically copied games from Super Nintendo cartridges to a 3.5" floppy. I think you could also skip the floppy drive and copy games directly to a PC, so this drive was optional.
The attachment 2238321771_13e042bf17.jpg is no longer available
I wanted to see what it contained and maybe also if I could hook it up to a PC with some modified drivers.
As you'd expect it is just a regular 3.5 disk drive with a PCB. I'm really no expert on these things but the traces from the 25 pin parallel port to the 34 pin floppy connector looks easily traceable. Seems to me that lot of connectors are not used? Would be interesting to know what you guys think.
The attachment IMG_20210603_214432.jpg is no longer available
Also, what voltages do you think the adaptor should be? 12V maybe?
The drive itself is a Teac which is not too bad I guess. I guess I could actually test it in my PC.
The attachment IMG_20210603_214258.jpg is no longer available
Reply 1 of 3, by megatron-uk
Yep, Front Far East produced the Super Wildcard series of copiers. I have one of their devices - a Super Wildcard DX. Before the time of flash cards these were the defacto means of playing backups on consoles.
Completely obsolete now of course... Who wants to wait for 3 full floppies to be loaded and read into memory sequentially before starting Final Fantasy? 😁
https://www.target-earth.net
Reply 2 of 3, by Joakim
Do you know where to get drivers for the drive I have? I'm thinking of using the controller for something fun. The floppy drive is in a computer 🤣
Reply 3 of 3, by BitWrangler
It's probably in 4 bit mode where it uses 4 data lines and 4 of the status lines. Floppy drive probably takes 5V.
Sounds a lot like one of the IO Magic crimes against computerdom, heh, they made a lot of unusual and weirdly configured stuff. Though poking around their website from a few different eras shows no sign of it. Might have been some otherwise white box outfit trying to hook their consumer recognition.
There is a slim possibility, that drivers never existed for this... there were some laptops that had a dual mode parallel port, which had special floppy drives, where when one was connected it was handled by BIOS like an internal floppy drive. So if it's one of those, no regular DOS driver 🙁 However, these were around as a general solution for laptop users who found themselves floppyless, so still hope.
Edit: Ooops, the lighting on the thumbnail made me jump to conclusions, looked closer, it does have 8 data lines hooked up and few status lines, so I think it was meant to be used with a bidirectional parallel port.
