First post, by Jinxter
My SB AWE 32 - CT3780 is not detected.
Have tried with:
Diagnostic.exe
Test-SBP.exe
OPCLONE
Unisound
Averybody says that same thing - IO address not detected, or not not detected at IO address.
When using an SB16, AWE32 (CT3670) they are all detected. So i am ruling out the PC itself.
I have tried setting the jumpers to all possible IO addresses.
I have disabled the onboard CD-ROM interface.
I have measured the Voltage Regulators - they seams fine.
    1.82 MiB
    SB AWE 32 CT3780
Check out my YouTube channel: Retro Erik https://www.youtube.com/c/RetroErik
My collection: https://retro.hageseter.com
Reply 1 of 7, by BloodyCactus
did you use CTCM to configure the card? its the most "trustworthy" official way.
Reply 2 of 7, by Tiido
That dent on the oscillator could be the reason. Chances are EMU8000 is misbehaving when it is receiving no clock and causing rest to misbehave too. The Oscillator is 45.158400MHz (44100 * 1024), it shouldn't be difficult to find a compatible replacement since it is a standard frequency.
Reply 3 of 7, by Jinxter
BloodyCactus wrote on 2021-06-04, 14:26:
CTCM just gives the the dos prompt - no messages.
CTCU does not detect any pnp or legacy cards.
Reply 4 of 7, by BloodyCactus
Jinxter wrote on 2021-06-04, 14:38:
that to me is a huge red flag then
Reply 6 of 7, by mkarcher
Tempus wrote on 2021-06-04, 19:27:
Should CTCU detect AWE32 or any legacy cards in the first place? Shouldn't it just detect plug & play compatible cards?
Yes, you are right. CTCU will only auto-detect ISA PnP cards and mainboard resources, if there is a PNPBIOS compatible mainboard BIOS installed. You can manually add legacy cards, so CTCM gets to know which resources are unavailable for plug-and-play cards.
The CT3780 is no PnP card, so you don't need CTCM/CTCU. It should have a base address jumper to choose between 220 and 240. Sometimes, 240 conflicts with mainboard resources, but you want your soundblaster on 220 anyway. You might want to check the jumpered base address.
Reply 7 of 7, by BloodyCactus
doh! I didnt realise ISO0+ISO1 were the io address. I thought it was pnp 🙁 my bad.
