First post, by benfinkel
Hello,
I want to get Moraff's Dungeons of the Unforgiven running is DosBox with SVGA. Problem is that it doesn't use VESA, instead you have to pick the specific chipset you're working with.
My computer has a GeForce 4 MX 440 in it... here are the options in the game menu for chipset:
Tseng ET-4000
Trident
Ahead
ATI VGA Wonder
S3 Windows Accelerator
S3 Other (Elsa)
Cirrus Logic
WD Cards (like Diamond and Paradise)
I've tried them all and none work initially. Any ideas? Should I be running it in straight windows? Because I tried that and none of the options worked either.
Thanks!
--Ben
