First post, by Moogle!
I have a late model VLB Trident TGUI9440-1 (9641, Bios 5.7) that I would like to upgrade from 1MB to two, but I do not understand the silk-screened instructions on the PCB. I have also never seen 'resistor packs' done like this before.
Reply 1 of 7, by kixs
If this is your card, than it's already at 2MB. There are 8 chips soldered on the right side for 1MB and both sockets filled for another 1MB of memory. If it's still 1MB, than one or both chips in sockets could be broken.
Visit my AmiBay items for sale (updated: 2025-08-01). I also take requests 😉
Reply 2 of 7, by Moogle!
I put those chips in, and 1MB is still only detected.
Reply 3 of 7, by weedeewee
The resistors only decide about the bus width of the chips for the first and second megabyte, ie 4 bits or 16 bits.
They should not need to be altered unless you do some modding to the card. Adding memory to preplaced sockets is not modding.
no idea though why your added megabyte isn't detected.
Do not ask Why !
Reply 4 of 7, by Moogle!
Just popped those chips out and added two different chips. Still nothing. I may just buy more resistors and add them and see what happens, though I'm kind of leery of tearing it up. This card is surprisingly quick, and gave up very little to the Hercules S3 Trio64, may it rest in peace.
Reply 5 of 7, by weedeewee
looking at the photo the sockets seem a bit deformed ... is that a lens artifact or real? if real could be cause of bad contact...
Do not ask Why !
Reply 6 of 7, by Moogle!
Just the lens I had to use. Phone appears to have two cameras, and the other one wouldn't focus right.
Reply 7 of 7, by Moogle!
Minor breakthrough. I have found a picture of another card with the Ram done the other way, with the two big chips making up the one 1MB. What's better is I can also discern what pretty much all though other components are due to using through hole technology.
