First post, by dionb
Size does sometimes matter.
I have the motherboard and PSU from a Compaq Professional workstation AP550. Great i840 dual P3 goodness. The motherboard is standard enough apart from its PSU connectors, so it needs this specific PSU. And the PSU is BIG, more specifically 1cm higher than regular ATX PSUs:
135.69 KiB
113.33 KiB
114.52 KiB
Now, the obvious solution is to get an AP550 case, but they are way out of budget. Other solution is to butcher a regular case so the PSU sticks out the top, which I'd prefer to avoid if possible. I checked transplanting the innards of the PSU to a normal ATX PSau case, but it's chock full with components and a PCB daughterboard right up to the top, no luck there.
So ... I'm looking for an ATX case that could fit this beast. I happen to have a huge Coolermaster Stacker, but despite all its volume and the fact it can fit two PSUs, the individual PSUs have to be normal height. Also looked into a 'short, fat' case that had the PSU next to the motherboard instead of above it, but the PSU would then foul the CPUs.
Any suggestion for cases I could consider?
Reply 1 of 11, by pentiumspeed
Realize that both AP550 and ATX are same signals and voltages except fan if this one uses this.
All you do is map out the pinout of your AP550 voltages, power good and PWR_ON signal will be same. Then splice this to a seasonic modular harness then you can use standard ATX case from on now.
Use your multimeter to check voltages and signals. Take a 6 pin GPU connector and remap this also for the CPU's power.
Once you know, consider adding to the compaq power supplies pinout in my thread I created?
Cheers,
Great Northern aka Canada.
Reply 2 of 11, by BitWrangler
Around the millenium there was a bunch of "fat" mid tower, generic-ish beige-ish ATX cases, with about an inch clearance above the PSU. Typically would have 3 x 5.25 bays. So one of those and something to hack the hole taller would work if you wanna keep original PSU.
Reply 3 of 11, by Oetker
Am I correct in understanding that you wouldn't mind slightly modding a case for a larger rear opening, as long as there's room? I'd think that there must be some cases that use a bottom-mounted PSU with enough space between the PSU and the motherboard. Alternatively, the Corsair Carbine Air 540 has the PSU in its own section, seems enlarging the hole would be possible.
Reply 4 of 11, by mR_Slug
I think that Compaq PSU is a similar size to IBM PSUs from that era. I have crammed the IBM EPS12V PSUs into all sorts of midi tower cases. Antec/Chieftec cases come to mind. IIRC i could get two of the screw holes to line up properly.
The Retro Web | EISA .cfg Archive | Chip set Encyclopedia
Reply 8 of 11, by dionb
pentiumspeed wrote on 2021-06-27, 22:09:
Realize that both AP550 and ATX are same signals and voltages except fan if this one uses this. […]
Cheers,
That pinout's already been done:
Re: Weird Compaq Motherboard
Couple of weird ones there, so not 100% certain it's all regular ATX in terms of behaviour.
BitWrangler wrote on 2021-06-27, 22:18:
Sounds very much like what I'd be wanting. Do you have any pics by any chance?
Oetker wrote on 2021-06-27, 22:19:
Slightly modding is no problem, what I'd rather not have to do is cut a PSU-shaped hole in the top of my case (most ATX cases I have) or saw away internal structural elements (my Cooler Master Stacker). Looking at it, the Air 540 would do the trick, although that is one HUGE (and expensive) case and a bit too modern for my taste.
PC Hoarder Patrol wrote on 2021-06-28, 02:30:
Here's someone who managed it using the PSU fan screws as alternate mount points. and a bit of case modding.
https://www.voodooalert.de/board/forum/index. … 7355#post357355
Nice. Something similar would be my ideal solution.
waterbeesje wrote on 2021-06-28, 17:40:
My IBM 300pl uses a PSU that looks like it matches this ones size. If you could find one of those for less ...
Now that would be a lovely mashup. PSU does look very similar (if not smaller, which is hardly a problem), however that 300PL isn't ATX but something between LPX and NLX with a riser board. That would add a whole new set of challenges.
Reply 9 of 11, by BitWrangler
dionb wrote on 2021-06-28, 21:51:
The problem is a lot of them were nameless, this Chenming shows the layout pretty well... https://www.neweggbusiness.com/product/produc … m=9b-11-125-471 They were all pretty much identical inside and at the back with various bits of "flair" in having different plastics on the front, and maybe designs stamped into the side panels. Damn, you'd think there'd be a line of them still out there, they were everywhere, seems black is the new beige now, hard to be different.
Edit: Brits and Europeans might satisfy their beige lust here, http://www.evercase.co.uk/index.php?route=pro … gory&path=63_89 nothing that looks like it works for OP though.
Reply 10 of 11, by dionb
BitWrangler wrote on 2021-06-28, 22:16:
Not too obsessed with beige, I'm all for function over form. But your suggestion about "three 5.25" bays" might just have been the tip I needed. I dug around and checked the one case I hadn't looked at before: a 1999-era Packard Bell Spheris II midi tower. Originally it contained an MSI MS-6168 uATX i440BX motherboard with onboard Voodoo 3. I've moved that to a smaller Packard Bell Squarius II uATX mini tower (uATX boards belong in uATX cases IMHO), so the Spheris was empty and unused. I had assumed it would be a very tight fit, but I assumed wrong: it has about a centimeter of unused space above the ATX PSU.
This morning I took a good look at it, grabbed my Dremel and removed a few metal supports from the underside of the case top. I'm now about 1mm away from being able to slide the PSU right up to the back of the case, and even as it is I can fit it, just a few cm behind the back. Still have some mm to spare above the motherboard, so this will work regardless.
Had to go back to work before I could continue (or take pics), but I'm confident I can get this to fit. Here's a pic of a comparable case, you can see the >1cm space above the top 5.25" bay, which is also present at the back:
Reply 11 of 11, by dionb
Update:
Dremel cutting discs arrived so time to get to work.
Basically the operation consisted of cutting out a PSU-shaped hole in the top of the metal inner case, then carving out some new screw and power cord holes and finally trimming the inside of the plastic outer case so it wouldn't foul the PSU.
Just started:
132.25 KiB
End result for the metal parts:
66.8 KiB
118.17 KiB
91.39 KiB
Plastic on top:
128.85 KiB
Note that the plastic is filthy and is currently sitting in the dishwasher together with the other external parts to get all sprightly. I also gave the metal case a good vacuum and wipe, partly for aesthetics, partly to avoid conductive metal filings all over the place when I start to build.
Pretty satisfied with how it looks so far, only issue is that I had to cut through a reinforcing bar to get the hole snugly up to the back of the case. That means it's nowhere near as solid and you can see the topmost bit crumpling slightly when I screwed in the PSU.
