First post, by Zerthimon
Greetings!
Got subj and it works, but has no red color in 3dfx demos. The card is in perfect condition overall: clean, no visible bent pins, no missing SMD parts, no scratches on PCB, etc.
Drivers had no problem installing and running . Tried it in two different systems.
Is this repairable ? What else should be checked, tested ?
Any ideas are welcomed!
